1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year => 1969 Mustang => Topic started by: krelboyne on March 01, 2016, 02:32:53 PM
Title: Cast Aluminum Automatic Shifter Buckets or Housings
Post by: krelboyne on March 01, 2016, 02:32:53 PM
1969-70 Automatic shifter buckets or housings, as Ford called them (C9ZZ-7A306-A).
Two different versions, with small and large pawl for gear selection. By checking the chrome shift lever, it is easy to destinguish between the 1969 small pawl version, and the large pawl version found around the beginning of 1970.
(http://i174.photobucket.com/albums/w115/CougarCJ/th_IMG_1400-1028_zpsn1giutrb.jpg) (http://s174.photobucket.com/user/CougarCJ/media/IMG_1400-1028_zpsn1giutrb.jpg.html)
The 1969 pawl measures 0.100" inches, and the large pawl at 0.160" inches.
Mixing lever assemblies and cast aluminum buckets can result in excessive play when in PARK, or being unable to 'latch' the PARK position.
(http://i174.photobucket.com/albums/w115/CougarCJ/th_IMG_1397-1028_zpsgbpfrnal.jpg) (http://s174.photobucket.com/user/CougarCJ/media/IMG_1397-1028_zpsgbpfrnal.jpg.html)
These shifter buckets appear to be dated with a Julian 1-3 digit number, followed with a single number of 8, 9, or 0, for the year.
(http://i174.photobucket.com/albums/w115/CougarCJ/th_IMG_1399-1028_zps0nivbdoq.jpg) (http://s174.photobucket.com/user/CougarCJ/media/IMG_1399-1028_zps0nivbdoq.jpg.html)
Title: Re: Cast Aluminum Automatic Shifter Buckets or Housings
Post by: J_Speegle on March 01, 2016, 08:26:17 PM
Thanks for sharing another often overlooked detail. Ford had repetitive problems over the years with cars popping out of park - wonder if this is related.
Don't recall any mention in the TSB's  so was not aware of the change
