1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year => 1966 Mustang => Topic started by: MyRed66GT on March 06, 2016, 08:13:45 AM
Having a heck of a time trying to find the correct FoMoCo stamped belts for my engine. Need alternator belt, power steering belt and a/c compressor/air pump belt. 289 smog motor.
do you want NOS or reproductions?? both NPD & virginia classic mustang carry excellent repros.
Marti Auto Works reproduces belts too. I haven't bought from them yet so I'm interested to hear what others think of their belts. They look good in photos.
maw is the supplier for those vendors i mentioned.
So, "excellent" then? ;) Thanks!
I am not sure if it has changed but Marti used to take genuine Ford belts (closest modern equivalent) as the basis for and then ink stamping the correct engineering number on the belt. Pretty much the only game in town for reproduction belts . FYI back in the day most belts were raised letter heat stamped rather then ink stamped. The ink stamp and the indented number heat stamp were used to a much lessor degree over all.
I've seen NPD's and Virginia's belts but I am a bit confused as to which ones to order. NPD lists an alternator belt with A/C, C4AE-8620-A. The power steering belt is listed as power steering with A/C, C60E-8620-D. The A/C belt listed is C4ZE-8620-B. I thought the A/C belt also hit the smog pump pulley. They do not list a A/C with smog belt for 66. Mustangs Unlimited shows an alternator belt with TE, and a P/S belt with A/C. I think they following is correct for my motor: alternator belt hits alternator, water pump and lower pulley. 15/32"x 40". Power steering belt hits P/S pump, water pump and bottom pulleys. 15/32" x 49.75". A/C belt hits A/C compressor, air pump and bottom pulleys. 1/2" x 61.25".
Why don't you order direct from Marti Autoworks? That way there will be less chance for a wrong belt. The smog application is not very common which to no surprise is why vendors may not list the application.
I may do that Bob. I will check that out tonight.
Here are the 3 different type of belts provided by Marti Auto Works for a 66 that we're restoring with AC, Power Steering and Smog.
