1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year => 1967 Mustang => Topic started by: denonito on July 25, 2016, 01:29:35 AM
Is there a resource here to decode the bottom line on the PS pump tag?
The tag I have, I am assuming( I have had my '67 Coupe for 30 years so...), is from my original pump.
I will attach picture.
HBA BF
IF
6M13B
Would this be correct for my 1967 San Jose, "A" code, Auto, Coupe? or is there a decoder in the library?
This thread was the only one that came up on a search, but maybe my search terms didn't match the library terms.
Thanks for any help,
Jeff
HBA BF
IF
6M13B
Looks like it would decode as a pump assembled on December 13th 1966 - second shift (Ford supplied pump) . There is an article in the Library that focus's on decoding dates but the PS pump is not one that was included. Maybe the next version or second part
No problem - started a new thread since this one deals with color and paint
Richard,
Not a color question...even after 30 years, I remember looking at the pump on my '67 thinking...it's kinda blue-ish, but defintely not post 67 FORD blue.
I found a tag in my pile of Mustang stuff, I am assuming was from '67 "A" code coupe (pump is long gone..as a core for a rebuild).
You seemed to know the build date for the pump. Someone had a link to Stangersite, but he doesn't have the bottom line decoded.
Your tag seems similar to the one I found, the bottom line is 6M13B on mine, so is that 1966 build from the first digit, and then?
Week or plant or.. stangersite just says mfg info...
Could be Dec 13 1966 2nd shift.
+1
What Happened? No real problem but thought it might confuse a few that responded
denonito asked a question in the thread related to color of the ps pump. I responded and split it from the other thread making a new thread. He must not have responded through the notification (or didn't have that option chosen) so he asked the question again in the Color of PS Pump thread where he collected a couple of more responses :)
So I collected those and added them to the new thread so hopefully our new member will find them here in his own thread. All is good 8)
Here is some more info on the data decoding, hope it helps
http://www.stangerssite.com/FP_IDchart.html
Kevin Marti wrote a book titled:
The Mustang and Cougar Tagbook (1965-73 models)
It is the key that unlocks all those mysterious tags on your car.
Very worth while and handy to have.
+1 to the book.
The decoding of denonito's PS tag (specifically the date) makes perfect sense. But, I can't figure out mine (picture attached).
Any help will be appreciated.
Bob
Bob
My guess is it is a TRW pump and the leading character, which would be the month is actually the "1" in the middle line. I think typically this was found on the bottom line? I'm not sure why yours has it in the middle.
The rest is "W" for Wooldridge (TRW), "25" is the date, "7" is 67. I'm no expert and that's just based on a bit of research.
Hope it helps. I am sure others can give a more knowledgeable opinion.
Bill : Thanks for your reply. The "1" being the month makes sense as my car was built on January 31, 1967. The "W" for a TRW pump does "throw me" a bit, as I thought that only "Ford" pumps had the block "FoMoCo" on them. Is that incorrect ?
Bob
Bob,
I'm thinking that there were a lot of Ford suppliers that included "Ford" or "FoMoCo" on parts they made, TRW included. I guess though that is just instinct and I would have to do some research to find something specific.
I know that some of the parts I designed for Ford in the late 80's were this way. Ford paid us for the design and had that requirement.
John : Yes, I have seen this to be the case on other parts also. For some reason, I was under the (mis-) impression that the '67 PS pumps that were marked with the "FoMoCo" were the Ford pumps, and the TRW pumps were marked differently. That not apparently being the case, what are observable differences between the two pumps ? IE, is there an easy way to distinguish between the two other than the tag ?
Bob
