1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year => 1964 1/2 - 1965 => Topic started by: C5ZZ on September 18, 2016, 06:26:16 PM
Title: Fuel sending unit
Post by: C5ZZ on September 18, 2016, 06:26:16 PM
I have a Ford original in my 65 that goes to the full mark but not all the way to empty.
I have four other used Ford originals that either have the same problem or
reverse, they go to empty but not to full!
Any ideas?
Title: Re: Fuel sending unit
Post by: Bob Gaines on September 18, 2016, 07:06:52 PM
Any ideas?
Hook up sender outside of the tank . I would rig up a long wire extension so you can sit in the driver seat and observe the gauge otherwise you have to have a helper work the gauge as you work the sender. Of course you have to provide a ground for the sender . Observe the way the gauge works as you move the float arm . You may just have a dead spot on the wrapped wire of the rheostat that needs a little sand paper from varnish build up. It could be the float arm needs a little bending . It could be a combination. Since you have a range of issues opposite each other indicates to me that your gauge is not the main fault.  I have revived a large number of senders over the years and these are just a few things that I have done in the past that have made a differance. Others may have a different way.
Post by: C5ZZ on September 19, 2016, 09:48:44 PM
Thanks Bob for the info, I tested them how you mentioned and
thats how I came up with the differences in them, helped a
friend do the same on his car, we bend his tabs/stops and
that seemed to help his problem.
Post by: J_Speegle on September 19, 2016, 10:47:19 PM
Thought there was a possible adjustment done/possible at the gauge. Will need to look through papers and books to see if I can find the reference
Post by: sgl66 on September 19, 2016, 11:13:49 PM
I was thinking the same, it's shown in here http://www.mustangandfords.com/how-to/interior-electrical/mump-1005-ford-mustang-instrument-panel-troubleshooting/
If I had to make a choice, I would use a sender that registered E when there was still 1-2 gallons in the tank and may not get to F rather than read 1/8 when bone dry.
Post by: Bob Gaines on September 20, 2016, 12:24:24 AM
Don't neglect to try cleaning off the wrapped wire as not making good contact could cause the symptoms also.
