1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year => 1968 Mustang => Topic started by: mhubert89 on September 27, 2016, 12:39:57 AM
Title: 68 brake booster vacuum !?
Post by: mhubert89 on September 27, 2016, 12:39:57 AM
Hi ,
When i buy my car , this vacuum fitting was on my intake .. Its is a original one for my car or what suppose to look the fitting that go on the rear of the intake for the vacuum ?
Title: Re: 68 brake booster vacuum !?
Post by: J_Speegle on September 27, 2016, 01:31:04 AM
Hi ,
Looks like the right piece difficult to say for sure with one angle only
The big plug is removed and replaced with a steel formed tube and a fitting to attach it to the vacuum block like other years. The rubber flex line that runs to the PB booster is attached to the end of the steel tube/line
Picture shows a rear vacuum block for a non-PS car the way its configured at the moment
This block screws into another odd shaped vacuum attachment that attaches to the intake on a 68 C & J code
Post by: ruppstang on September 27, 2016, 09:38:13 AM
I stole this from another thread. It shows the complete assembly.
Post by: mhubert89 on September 27, 2016, 11:09:42 AM
Oki perfect . So if i put PB on my car this block its not good and need to buy one for a PB !!?
Post by: jwc66k on September 27, 2016, 04:49:50 PM
The one you have in your picture has four small capped ports, one medium port and one threaded hole that is plugged. Replace the plug with a power brake tube fitting and you can hook up the vacuum required there. The tube fitting looks like the one Marty has in his picture.
Post by: J_Speegle on September 27, 2016, 09:46:44 PM
+1 At least that is what it looks like from the picture you posted. Just need the "spark plug" looking fitting to attach it to
Fitting arrangement for a non- PS set up
(http://www.concoursmustang.com/forum/gallery/6/6-270916204530-62941336.jpeg)
With the plug removed - point of attachment for the PB tube and fitting
(http://www.concoursmustang.com/forum/gallery/6/6-270916204528-62931749.jpeg)
Post by: mhubert89 on October 06, 2016, 09:10:52 AM
Oki thanks for the picture
