1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year => 1969 Mustang => Topic started by: drummingrocks on August 09, 2010, 10:39:22 AM
Title: '69 Mach: Holes in Doorjamb for Courtesy Light Wiring
Post by: drummingrocks on August 09, 2010, 10:39:22 AM
I have a set of '70 doors that I'm putting on my '69 Mach 1.  These doors don't have the holes around the hinge area for the courtesy light wiring to pass through.  I need to drill these holes, but I don't have the original courtesy light wiring harness or the grommet that would tell me what size hole to drill.
I'm assuming that the door grommet is the same size as the one that goes through under the A-pillar, which is, if I remember correctly, 1 3/4th inch.  However, I'd hate to break out the hole saw and put the wrong size hole in the doors.  Can someone verify how big the holes in the doors should be?  Thanks!
Title: Re: '69 Mach: Holes in Doorjamb for Courtesy Light Wiring
Post by: BillEBobb on August 11, 2010, 12:11:11 AM
It's 2-3/16"   My doors are laying on the garage floor awaiting installation so I was able to get you this measurement.
Post by: drummingrocks on August 12, 2010, 06:10:11 PM
Bill,
Thanks for your help!  It seems like these holes are a LOT bigger than I anticipated--good thing I didn't go ahead and drill the smaller sized holes!
You wouldn't happen to have the original harness laying around, would you?  It would be great to see the grommets on the harness as well.  Thank you!
Post by: BillEBobb on August 13, 2010, 10:34:07 AM
Bill,
I'll see what I can do.
Post by: BillEBobb on August 15, 2010, 07:10:48 PM
I've got a set "somewhere" in the garage but haven't been able to find the for you.  I'll take a picture of the set I'm working with ON the car now.  I'll photograph them soon for you.
Post by: drummingrocks on August 15, 2010, 07:47:30 PM
Bill, it's ok, I was able to look at the harness on a local car.  I got the holes drilled in my doors.
Thanks for all of your help!
