1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year => 1966 Mustang => Topic started by: Morsel on April 30, 2018, 03:23:04 PM
Title: 66 Parking brake cable retaining brackets finish and head markings if any?
Post by: Morsel on April 30, 2018, 03:23:04 PM
1966, February 10th, San Jose Build.
I'm wondering about the parking brake cable bracket and bolts... I assuming the finish is natural for both of the brackets themselves, but read somewhere in one of the threads that one was painted and one was natural, but maybe they were talking about something else. Also, was there any head markings on the four bolt heads? I've attached a picture for reference of the brackets I'm speaking of.
Thanks as always,
Jason
Title: Re: 66 Parking brake cable retaining brackets finish and head markings if any?
Post by: jwc66k on April 30, 2018, 04:40:53 PM
My Oct 65 San Jose hardtop brake cable bolts were clear zinc plated and the brackets were cad plated (possibly zinc). That is based on the appearance of the unexposed surfaces of both when removed. The exposed surfaces were rust.
Post by: Morsel on April 30, 2018, 05:08:48 PM
Hey Jim, did you have any head markings on the bolts? Mine were so badly rusted I couldn't make out anything.
Jason
Post by: J_Speegle on April 30, 2018, 06:32:34 PM
Yes there were typical markings
This example is from a little later in the production year. Looks like the often seen diamond IMHO
(http://www.concoursmustang.com/forum/gallery/10/6-300418173100.jpeg)
Post by: jwc66k on April 30, 2018, 07:47:31 PM
As Jeff's picture "showed", a diamond head was the most common. Another "possibility" could be a "D".
Post by: Morsel on April 30, 2018, 07:56:37 PM
Thanks all, this is perfect...
Jason
Post by: rrenz on May 02, 2018, 09:42:56 PM
originals from my 66 Jan NJ
Post by: dsielke on May 02, 2018, 11:38:48 PM
1966 San Jose, Build date Dec. 1, 65.
Post by: J_Speegle on May 02, 2018, 11:40:57 PM
Can't make out the head markings. Can you describe or confirm they match others posted for the record :)
Post by: dsielke on May 03, 2018, 01:34:41 AM
Looking at a higher res version of the images I have it looks like a D, but I could be wrong. I can try to look when I get a chance.
Post by: Morsel on May 03, 2018, 02:51:45 PM
This is a month and a half before my build, probably a good indicator for my car or something to follow at least...
Thanks for the info.
Jason
Post by: Bob Gaines on May 03, 2018, 07:16:12 PM
I can tell from the picture posted that it is a "D". The brackets appear to be restored (cleaned with slight pitting). I think the diamond would be more common for SJ through 66 IMO. I am skeptical that the "D" hasn't been switched out but can't rule out the "D" marking. If I wasn't absolutely for sure that it was original hardware I would go with the more common IMO diamond if it was my car but that is just me. Good Karma for the effort of posting pictures regardless.
Post by: outlawincorporated on May 04, 2018, 10:23:04 PM
JASON
I will send you some pictures via email shortly of what I have just taken off a car very close date wise and assembly plant to your K code
just so every one else knows the D version bolts is what I have. finish wise I assume it was just a heat treated dark steel colour.
regards.
PHILL BERESFORD.
MELBOURNE.
AUSTRALIA.
Post by: Bob Gaines on May 05, 2018, 01:00:04 AM
JASON
regards.
PHILL BERESFORD.
MELBOURNE.
AUSTRALIA.
Not to be splitting hairs but the dark color would not be heat treated in the case of a dark color on this particular fastener but S2  P/O. The heat treating was more for strength and the P/O was to prevent corrosion although minimal at best. Not to say that there could not be anomalies but I have observed numerous times a S8 silver finish on this particular screw used for the bracket. That was typically SJ cars I was seeing it on. The engineering drawing/assembly manual seems to support what I have seen so I never questioned it when the two matched up.
Post by: dsielke on May 05, 2018, 02:13:57 AM
Bob, The undercarriage on my convertible was coated in dealer undercoating and all I have done is clean it with mineral spirits. The screws are nickel plated or whatever the shinny finish is and the brackets are bare metal, no pitting but there is some discoloration probably from more than 50years coated with undercoating. All are positively original on this car.
This is what the same area looked like before and after cleaning. You can follow my ongoing undercarriage cleaning in the restoration section to see how much of the rest of my undercarriage has been nicely preserved.  :)
Post by: Bob Gaines on May 05, 2018, 12:55:18 PM
Wow what a striking positive difference IMO given the before and after pics.  I have done it before so I appreciate the effort.
