1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year => 1969 Mustang => Topic started by: chrint on May 10, 2018, 05:43:08 AM
Title: Leaf/coil spring paint marking colours- 69 CJ 4 speed Mach I
Post by: chrint on May 10, 2018, 05:43:08 AM
I'm after the correct colour paint markings for my 1969 Dearborn made Mach-1 428 Q-code CJ 4 speed car. Non a/c car
My car was made 10/09/1968, require both rear leaf spring and front coil spring paint colours and any pictures /examples of the way they were done from the factory.
Title: Re: Leaf/coil spring paint marking colours- 69 CJ 4 speed Mach I
Post by: J_Speegle on May 10, 2018, 03:55:15 PM
First, forgot to do this with your first post, welcome to the site. Hope you find the information hear helpful and on point with our focus here
For your application as shown above
Front coil springs were likely - 1 Gold and 1 Pink stripe. Suggestions as to how they were marked can be found in other coil spring threads and the article mentioned below. This will help with direction of drips and splatter often produced during application.
Rear leaf springs were likely marked C9AZ-5556-G  with stripes of Gold and Violet
Bottom one in this example
(http://www.concoursmustang.com/forum/gallery/8/6-020917164121-86291683.jpeg)
And a restored set of markings. Have seen them in both order from front to back. Just happened sometimes
(http://www.concoursmustang.com/forum/gallery/7/6-210717185428-7599202.jpeg)
Information obtained from factory buildsheets and pictures of unrestored cars
Suggest you use the search feature of the site - there are many threads that show location and typical applications of the markings your looking for on 69's. Also Suggest, if you have not found it already, that you check out the article in the Library on basic paint marks. Articles are there so we don't have to repeat the same info multiple times in different threads and it provides a common base to start from. Got some reading to do ;)
Post by: specialed on May 10, 2018, 10:29:40 PM
Jeff i think u meant c9za  not c9az  rear spring id.
Post by: J_Speegle on May 10, 2018, 10:50:24 PM
Yes Thank you for pointing that out. Corrected the earlier post
Hope that is the only thing I did backwards today  ::)
Post by: chrint on May 11, 2018, 04:22:30 AM
Thankyou Jeff for all the use full information.
