1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year => 1964 1/2 - 1965 => Topic started by: 6T5 Fastback on June 01, 2018, 01:08:16 AM
My 1965 Fastback came with the Deluxe Pony Interior option. When I bought the car it had a blue steering wheel instead of the woodgrain one ? Was the wood an option? The rest of the interior has the woodgrain inserts and the pony seats. I decide to upgrade to the woodgrain wheel and now the wheel clicks when turning and also does not cancel the signal after turning ? Any help would be great thanks
If it was a factory Pony/deluxe interior car, there will be several giveaways for '65. All deluxe interior Mustangs and factory GTs in 1965 received the '66-style instrument cluster with 5 gauges instead of the standard Falcon-style speedometer. On a standard interior car that's been converted to deluxe interior later in life, the instrument cluster swap is usually the hardest part since it involves cutting the dash and using a different underdash wiring harness. If you're wondering if the car originally came with the upgraded interior, pull the instrument cluster and take a look behind the dash. There should be a notch in the metal dash to clear the '66-style speedometer. If that notch is missing or looks like it was cut by hand, then the car started life as a standard interior car.
To answer the original question: if the car was a factory deluxe interior car, it came with the woodgrain steering wheel.
Also, welcome to the site!
