1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year => 1967 Mustang => Topic started by: orgnl70 on June 05, 2018, 05:54:25 PM
67 S code. Metuchen built. 11/17/66 build date.
What would be the correct finish for a Midland Ross brake booster.(FORD logo inscribed)
I have seen from gloss black to flat black.
Semi-gloss black. Ford logo is a service replacement.
+1 . You can make the Ford logo disappear with a little body work. That is if you care to make it look like assemblyline . I can only assume you are concerned given the level of sheen question.
Ditto on both Replies. And don't forget, the Master Cylinder should be attached to the Booster before painting as both should be painted together.
Bob
