1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year => 1966 Mustang => Topic started by: socalgt on June 07, 2018, 07:25:58 PM
Title: 1966 fuel line installation 289 a/c and power steering, original automate carb
Post by: socalgt on June 07, 2018, 07:25:58 PM
I'm struggling again installing a correct( well, repo) fuel line.  With the a/c installed and power steering I can't fit the fuel line...specifically fitting it in the small opening between the p.s. pump bracket and the block itself.  This is a repeat post, as I still find it difficult if not impossible.  I'm going to assume the factory installed the line before installing the a/c and power steering, but I don't plan on removing them to install the fuel line.  Looking for suggestions....again.
Thanks...
Title: Re: 1966 fuel line installation 289 a/c and power steering, original automate carb
Post by: jwc66k on June 07, 2018, 08:01:43 PM
Consider doing it "right". Remove the A/C and PS.
You can thank me tomorrow.
Post by: socalgt on June 08, 2018, 09:46:39 AM
That's certainly an option....but that's not easy, especially removing the bolts from underneath  the a/c compressor.  I'm going to try to loosen the a/c and p.s. mounting brackets just enough to sneak the line in.
Thanks....
Post by: 67gtasanjose on June 08, 2018, 11:18:21 AM
Take the PS pump down first, you should then easily reach the bolts going into the head for the compressor mounting bracket. I leave the compressor attached to the mounting bracket when I've done this.
Upon re-install, use the long stud bolt to hold the weight of the compressor. You most likely will need to separate the nut from the stud since it almost always stays on the long stud when removed.
Post by: socalgt on June 09, 2018, 12:00:06 PM
Thanks.....looks like that might be the "easiest" way to get the fuel line installed without complete removal of the compressor and p.s. bracket.
