Restoring - General discussions that span across many different groups of years and models => Misc Items => Topic started by: socalgt on June 28, 2018, 01:42:43 PM
Title: power steering belt/pulley squeak
Post by: socalgt on June 28, 2018, 01:42:43 PM
I isolated the squeaking to the power steering pump belt.  I've tried two new belts, but regardless of the tension, the squeak remains....so....could it be the pulley itself?  It has a slight wobble to it, and always has, but is not loose and the pump has no leaks.  I'll try one more belt.  The belts I've tried have the "notch" pattern, rather than the continuous rubber on the side that runs on the pulley......I've tried the smooth belt also.....still squeaks.
