Restoring - General discussions that span across many different groups of years and models => Body, Paint & Sealers => Topic started by: aaatp on October 07, 2010, 04:11:31 PM
Hey Guys: My 66 Dearborn convertible, built in late Feb. of 66, is at the body shop. We are trying to determine
what the bow or curve should be in the tail light panel from the ends to the center, if any. The car was hit there along time ago,and the original shape is not there. I was thinking maybe 1/2 to a 1/4 of an inch. I noticed that the decklid has some curve to it also, but am not sure if it was also hit. If some one could give me a dimension, it sure would help. Any help would really be appreciated.
Thanks Much: John
Bolt on an OEM rear bumper and original trunk lid and you'll get your fit.
I would assemble the rear valence, trunk lid, bumper, fender extensions, and tail lights together as a system and "adjust" as necessary until all gaps are uniform/to your satisfaction. You will know pretty quickly if the tail panel is out if it does not match the trunk lid and bumper.
The gasket on the trunk lid will change the position slightly, so if you settle on a trunk lid position without the gasket installed you might not be able to get the lid into the same position during final assembly. You might want to think about sacrificing a gasket for this step or if you only want to use one gasket, temporarily tape it in place.
