1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year => 1966 Shelby => Topic started by: J_Speegle on October 05, 2018, 09:12:54 PM
Title: 66 GT350 - Running Changes Thread
Post by: J_Speegle on October 05, 2018, 09:12:54 PM
Though this might be a good thread to start considering we have a 66 San Jose Running Changes Thread for Mustangs where we've been trying to track San Jose changes that affected how the Shelby's would have also been assembled.  As long as we're going through a specific year and plant I though a partner thread would be helpful to try and narrow down the 66 Shelby running changes at the same time.  The Registry lists many of these but not all of them. Don't expect to find a great difference between the Registry findings and the findings in this thread but we'll see. Hopefully they will support one another.
Hope all of this this helps owners and builders with some additional information when it comes time to restore one of these cars. In most cases if your car is a nice unrestored examples (less and less of these are out there) we're interested in your findings and these findings on their own should not be used alone to make a change to your car only start the discussion.  We hope this thread helps those who's cars may have been altered or restored in the past make some educated choices as they go forward.
Posted the other day a graphic I was thinking about incorporating in surveys and results of running changes on the site to graphically represent know or confirmed ranges of the two or more versions as well as the "gray area" at the time of the study. It was suggested that we give it a try with a pilot. To that end figured we would start with an easy even year thread since the second year of a body style normally has less of these changes. So post what you understand was affected by running changes and I'll keep an ongoing list here in the first post. From there we'll collect data, assemble the first report and see how it works.
To keep the thread from getting too long or out of hand please don't post that you found this version or that on car 6F07C234512. We can save that for the research period. Just trying to identify the features during this first effort. Will break out the findings by plant of course. Will be adding additional items as time goes along. Don't post your submissions to this thread but instead to the individual threads that discuss that particular detail. Those will be linked to the study items below as we have done in the 66 San Jose Mustang Running Change thread
http://www.concoursmustang.com/forum/index.php?topic=14786.msg119022#msg119022 (http://www.concoursmustang.com/forum/index.php?topic=14786.msg119022#msg119022)
1- Door sill plate label design change. shelby american, inc  (single line) or shelby american, inc    los angeles, california (two lines)
http://www.concoursmustang.com/forum/index.php?topic=17911.msg113180#msg113180 (http://www.concoursmustang.com/forum/index.php?topic=17911.msg113180#msg113180)
2- Rear scoop duct attachment orientation.
Duct color white to black approx 6S050 and 6S280.
Duct attachment. Change from inner to outer somewhere between approx 6S2020 and 6S2070
http://www.concoursmustang.com/forum/index.php?topic=20351.new#new (http://www.concoursmustang.com/forum/index.php?topic=20351.new#new)
3- Tach face (Cobra) location change.
4- Rear COBRA taillight panel emblem.
5- Valve covers - Open letter verses closed letter.
6- Valve covers - Retaining bolt spreader plates.
7- Micro master cylinder installation.
8-  Intake manifold style.
9- Front shock mounts - with or without export package style washers.
10- Shocks - Koni or FoMoCo adjustables made by Gabriel.
11- Lemans stripe application pattern.
12- Traction bars - Over or under axle.
13- Manual transmission details/changes
14- Rear brake drum change from 3 nubs to no nubs.
15- Header (at engine flange) bolt head markings.
16- Kelsey Hayes rear brake backing plates. KH-49294 (R), KH-49295 (L) versus KH-70390 (R), KH-70391 (L).
17- Seat belt supplier (Ray Brown vs Impact) and variations within each (long vs short floor hooks, long vs short tongue, leather pad attached to tongue or clasp, etc.)
Title: Re: 66 GT350 - Running Changes Thread
Post by: Bob Gaines on October 06, 2018, 12:26:51 AM
Over ride traction bars vs under ride.
Post by: Bob Gaines on October 06, 2018, 12:30:14 AM
 engineering number identification style on radiator raised letter and number in tank vs soldered on tag.
Post by: Bob Gaines on October 06, 2018, 12:32:35 AM
All aluminum manual transmission vs cast iron tallshaft and or side cover.
Post by: J_Speegle on October 06, 2018, 12:38:32 AM
Thanks Bob. Added the others but this one would fall under the 66 Mustang running changes ;)
Post by: Bob Gaines on October 06, 2018, 12:47:10 AM
Sorry about that.  How about 2 1/2 brake drums with the 3 nubs vs no nubs.
Post by: J_Speegle on October 06, 2018, 04:42:33 PM
That one is going to be hard to confirm but will add it to the list  :)
Post by: Bob Gaines on October 06, 2018, 05:12:30 PM
I am not sure when it changed over other then in later 66 Shelby production. If it was easy anyone could do it LOL.
Post by: silverton_ford on October 08, 2018, 06:41:22 PM
How about the hoods?   All fiberglass, fiberglass with steel inner, steel hood with steel scoop.....etc.
Post by: J_Speegle on October 08, 2018, 07:02:02 PM
We can do a survey unfortunately so many cars have changed their hoods for other ones including reproductions. Would require date codes from each example but we can look into it and see if a pattern shows up
Post by: silverton_ford on October 08, 2018, 07:12:58 PM
Header bolts.
I know it has been discussed in older threads, but just thought it could go well here too.
Post by: J_Speegle on October 08, 2018, 09:45:50 PM
Header bolts.
Added
Post by: s2ms on November 04, 2018, 03:38:52 PM
Rear brake backing plate KH numbers. KH-49294 (R), KH-49295 (L) versus KH-70390 (R), KH-70391 (L).
Seat belt mfg (Ray Brown vs Impact) and variations within each (long vs short floor hooks, long vs short tongue, leather pad attached to tongue or clasp, etc.)
Pump to carb fuel line?
Post by: J_Speegle on November 04, 2018, 05:10:20 PM
The seat belt once may be a pretty big challenge but we'll see once we get a focus on it
