1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year => 1970 Boss => Topic started by: SCJSTU on October 29, 2018, 01:43:46 PM
Title: correct distributor 1970 351C
Post by: SCJSTU on October 29, 2018, 01:43:46 PM
late build June 1970 351C....auto, ac Dearborn convertible
would it have an Autolite or Motorcraft?
casting numbers?
Title: Re: correct distributor 1970 351C
Post by: J_Speegle on October 29, 2018, 04:10:58 PM
Easy one first - would be cast with the Autolite script in the housing. Motorcraft didn't come into use for a few more years.
Post by: cobrajet_carl on October 29, 2018, 07:19:00 PM
Probably D0OF-Z but late 70 AT usually got the distributor modulator system don't know if that makes any difference
Post by: 70cj428 on October 29, 2018, 09:30:49 PM
M code or H code ?
My Late Dearborn M code Mach1 (Auto, AC) has a D0OF-Z Distributor, I'm sure it's original.
Hope this helps, John
 EDIT... I took my comment about the 2bbl Distributor out cause I'm not sure it's right. The 70 Shop manual specifies an AO suffix but everything else I read says otherwise .....
Post by: SCJSTU on October 29, 2018, 09:54:06 PM
M code or H code ?
My Late Dearborn M code Mach1 (Auto, AC) has a D0OF-Z Distributor, I'm sure it's original. I think an H code (Auto) would be a D0AF-AO
M code car
Post by: jwc66k on October 30, 2018, 12:27:25 AM
casting numbers?
Did you look in the Forum's Library?
Post by: SCJSTU on October 30, 2018, 12:45:37 PM
Thanks Jim, never knew to look there great info...
assume the last column is for a Motorcraft service replacement and the factory originals are all Autolite on the chart?
