1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year => 1970 Mustang => Topic started by: Cobrajetken on December 17, 2018, 11:01:25 PM
Title: 1970 Mach 1 351 C valve cover engine code
Post by: Cobrajetken on December 17, 2018, 11:01:25 PM
Can anyone help me determine the correct coding for the valve cover decal on a 1970 Mach 1 Mustang 351 Cleveland 4V , automatic, non ram air, non shaker. Thanks. Ken
Title: Re: 1970 Mach 1 351 C valve cover engine code
Post by: jwc66k on December 18, 2018, 12:15:56 AM
Welcome to the forum.
The information you are looking for is referenced in the Ford Car Parts manual which you can download from this site:
http://squarebirds.org/Manuals/1965/1965-72FordPartsTextCatalog/
It's in the text section on engines.
Post by: cobrajet_carl on December 19, 2018, 11:02:54 AM
Build sheet, the original metal tag. Failing that a deluxe Marti might help with figuring it out.  ECS doesn't list that application but I think they could make one if they knew the options and build date. Base code number could be K609A. Did you mean non A/C, non shaker?
Post by: krelboyne on December 19, 2018, 12:03:56 PM
Kevin Marti's tag book shows 608 for 1970 M code with manual transmission.
Post by: J_Speegle on December 20, 2018, 01:30:44 AM
Hi Ken welcome to the site - hope you find the help, information and support your looking for related to your concours related endeavors
Currently on my laptop so screen is too small to read all the right boxes in a buildsheet to figure out the correct codes for your application but will get to it. Don't think I can supply the rest of the codes (plant and timing I believe) since I don't have a bunch of original labels. Most often hidden behind AC pumps or did live almost 50 years
Will report back
Post by: 70cj428 on December 25, 2018, 09:02:34 AM
My M code, Auto, Non Ram Air, Non Cali. emissions, with AC Mach1 has K609AG on the build sheet and on the original engine tag, I'm almost certain that the Non Air version of the same car would be the same code without the "G" on the end...
Hope this helps, John
