Restoring - General discussions that span across many different groups of years and models => Suspension => Topic started by: 68 S Code on November 14, 2010, 10:03:27 AM
Title: Ps boot clamps
Post by: 68 S Code on November 14, 2010, 10:03:27 AM
I am detailing the PS cylinder with a new boot at the stud end and a new accordion boot at the PS valve assembly. These boots are held on with a metal ring which uses a special tool to crimp it. The tool is available but where do you get the large ring for the cylinder boot. I heard many just use a plastic zip tie instead. I would rather find a ring. But where, NPd, amk?
Title: Re: Ps boot clamps
Post by: CharlesTurner on November 14, 2010, 01:02:53 PM
I'm pretty sure the large clamp comes in the end boot kit, which is available in reproduction from most any mustang parts place.
Post by: Bob Gaines on November 14, 2010, 01:24:20 PM
The same type of crimp clamp is also used on the power booster vacuum supply line . This info may also help source it. Check Mansfield Mustang I believe he may sell them individually . Bob
Post by: carlite65 on November 14, 2010, 01:49:04 PM
virginia mustang has it under p/n PE609.
Post by: 68 S Code on November 14, 2010, 11:35:36 PM
Thanks guys for the lead. I bought the end boot and it didn't come with the crimp clamp.
Post by: 68 S Code on November 15, 2010, 10:16:23 PM
Did some curving of the retailers mentioned and they had them. Thanks again guys.
Post by: T Lea on November 15, 2010, 10:44:19 PM
On a related question, what are people opinions on yellow clamps on the large boot, ever seen them?
Post by: gtamustang on November 16, 2010, 04:17:00 PM
Are you refering to the stud end bood or the ram boot? Either way I have not seen any yellow band clamps on the boots. I wonder what the reasoning would be for a different color clamp.
Regards,
Pete Morgan
Post by: 68 S Code on November 16, 2010, 10:38:44 PM
Yellow meaning zinc di-chromate? One other question. The accordion boot on the steering valve assembly isn't held on in any way at the bigger diameter end? I know there is a crimp clamp at the small end.
Post by: T Lea on November 16, 2010, 11:05:44 PM
Regards,
Pete Morgan
The stud end boot. have seen a couple yellow ones, not zinc dicromate but yellow. Have no idea what thats about.
Post by: Bob Gaines on November 17, 2010, 12:33:20 AM
I have mostly seen white. it was as if painted . Reminants remained under the band when taking off the boot. Bob
Post by: T Lea on November 17, 2010, 08:57:36 AM
Could be a white that appeared yellowish from age
Post by: J_Speegle on November 17, 2010, 11:54:57 PM
Have not seen a yellow one as of yet - any year
