1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year => 1970 Mustang => Topic started by: HDAshmore on May 16, 2019, 07:39:13 PM
Title: 1970 AC vent dissassembly/reassembly question for restoration
Post by: HDAshmore on May 16, 2019, 07:39:13 PM
Good Afternoon All,
Question on disassembly of AC vents for 70 Mach 1.  I am prepping things for Vacuum Ornametal and do not know how to take the side AC vents apart for rechrome of the round vent edges.  I see the three little gray rivets that hold the back piece to the front piece and I assume keeps the vent ball sandwiched between.  It appears I drill out two of the three as one looks to be an index rivet.  So if that is how I get it apart, my real problem is how and what do I use/do to put it back together once I get parts back.  I plan on replacing the felt once apart and painting the front piece but no clue on reassembly requirements. Is there special rivets or tools I need for this?  Lastly, anything I should be aware of on center vent?
Dan in Kansas
Title: Re: 1970 AC vent dissassembly/reassembly question for restoration
Post by: J_Speegle on May 16, 2019, 08:03:14 PM
Got a picture of the back side of the assembly. Kind of recall but need a refresher :) to see if have can help
Post by: HDAshmore on May 16, 2019, 09:49:10 PM
Duh on my part, wrong side pic.  Thanks for responding so quickly.  The little gray pot metal rivets by the screws are what is throwing me.  I assume if I drill those out it comes apart?  Then my real problem is how do I put it back together?  Where do you get stuff like that and the tool I guess is my real problem.
Post by: 69GT350H on May 17, 2019, 02:34:02 AM
If you carefully drill the rivets out, you can use screws to put the vents back together.
(https://redshost.com/gt350/images/20180728_145649.jpg)
Post by: HDAshmore on May 17, 2019, 08:48:34 AM
Thanks, that's two who have said to use screws.  Any other ides before I go down that route.  My fear is once all done and assembled that they might work themselves loose.  I do not want to pull that dash anymore than I have to. Too old, fat, brittle and stiff to be that too many more times.  Thanks for the ideas so far.
Post by: 1966KGT on May 17, 2019, 11:17:02 AM
Small dab of green Loctite will keep them snug and make them easy to remove if needed. Use it often on small diameter fastners.
Post by: BlackMcode1970mach1 on May 30, 2019, 07:00:26 PM
Im doing my dash also , im going the ac route .. My car was a non ac car.. where can I get felt for the vents? Maybe a stupid q but ..  also  im cleaning up my dash on the back side im using a drill with a  80 grit wheel.. anyone got any other ideas what I can use to get into the crevices?? I don't have a media blaster , I use evapo rust on lots of stuff. .        any ideas qould be appreciated.! Mark
Post by: HDAshmore on May 30, 2019, 08:51:33 PM
I am trying to figure it out also on surface rust on the back side of the dash.  I was hopeful vapoblasting with bobby would be the trick but sadly dash is too large for machine.  I am thinking some kind of liquid rust remover then boeshield but I'm just pondering possibilities right now.
Dan
Post by: 1966KGT on May 31, 2019, 08:47:59 AM
possibility of using small hand held soda blaster for back of dash?
Post by: BlackMcode1970mach1 on May 31, 2019, 10:49:49 PM
I was thinKing that too! I sold my old eastwood blaster when I had moved..  didn't think id ever get a car again.  ha
Post by: J_Speegle on June 01, 2019, 12:02:27 AM
Might be better off chemically cleaning/stripping the metal so that areas where there is metal overlapping metal areas get stripped of rust and treated.
Just a thought
Post by: HDAshmore on June 01, 2019, 10:24:15 AM
I think chemical is the way to go
  Maybe phosphoric acid then boeshield, or vinegar?
Post by: J_Speegle on June 01, 2019, 05:54:55 PM
Since your dash comes out, unlike earlier models. another possibility might be evaporust. They do make a gel also - have not tested or used it yet but it would eliminate the need to make a dip tank from boxes and a plastic liner - plus allot of product If your going to need to oil then you will need to wait till after the paint coat on the face and flow it into the seams. Some owners/builders mitgh choose to paint the back side with a "natural" looking paint since it will be difficult to see once installed
Post by: HDAshmore on June 02, 2019, 09:43:35 AM
Evaporust would take too much to fill trough big enough to the to do job so I decided not to even consider it.  My reconsider vice gel vs liquid.  My other big issuebis stripping bthe paint so I will get after that with liqued stripper but hard to find a good stripper now days with all the laws etc... There's a joke in there somewhere 😁
I'll probably clear the backside once rust is chemically removed reagrdless of how it all comes off then oil all the little cracks and crevices.  Thanks for all the feedback.
Dan
Post by: jwc66k on June 02, 2019, 02:54:06 PM
The Evaporust website show a Dodge frame being "treated" by using a spray bottle with the stuff. Go read the site about that.
Post by: J_Speegle on June 02, 2019, 04:54:37 PM
Sometimes just talking things through helps allot
Glad we can help
Post by: ninedrvr on March 08, 2022, 11:10:47 AM
Good Afternoon All,
Dan in Kansas
Did you end up sending them out and if so how did they turn out?
Post by: AJ on November 24, 2023, 10:30:33 PM
I realize this is an old thread but i wanted to share my recent experience using evaporust on lower dash.  What worked well for was laying paper towels that were saturated with evaporust on the areas of the lower dash that i wanted to derust.   Then use thin polyfilm , like 1 mil thick or so, over the saturated paper towels to prevent evaporation.  Periodically remove the plastic and reapply a bit more evaporust by brush then cover with plastic.  The idea is to maintain dwell time of the evaporust.   The soaked paper towels conform easily to the irregular shapes.  And the plastic cohesively bonds to the saturated paper towels.
Post by: J_Speegle on November 24, 2023, 10:34:49 PM
AJ thanks for sharing your experiences. No problem adding these to older threads. Works out better in the long run rather than having tips, tricks and experiences spread across multiple threads and post
Post by: BHStang on November 28, 2023, 11:16:29 AM
When I did mine I put screws back in and added some JB weld to really make sure they were not coming back out.  For stripping I did low pressure walnut shell and then cleaned with a soft brass brush.
