Restoring - General discussions that span across many different groups of years and models => Drivetrain => Topic started by: Snydly289 on August 04, 2019, 11:39:13 PM
Title: 9" Rear Axle Housing "J" Brake Line Tab Replacement
Post by: Snydly289 on August 04, 2019, 11:39:13 PM
Hi all,
I am currently restoring my 65 K 9" axle housing and I need to replace a broken brake line "J" tab keeper. Is there a vendor that makes these weld on tabs like the original or am I going to have to rob one off of another axle housing?
Riley
Title: Re: 9" Rear Axle Housing "J" Brake Line Tab Replacement
Post by: Bob Gaines on August 05, 2019, 03:09:47 PM
Make one or rob one from another. It is not a common thing to have to be replaced. That is probably the main reason why they are not typically available from main stream vendors.
Post by: J_Speegle on August 05, 2019, 04:18:38 PM
Another option is to make your own out of standard strip of metal using the other as a pattern. Likely best to drill a hole and plug weld it then grind and dress the surface
Post by: Snydly289 on August 07, 2019, 05:33:34 PM
Thanks for the replies guys, looks like I'll try to carefully rob one off of my 8" axles in my ever growing "parts pile"
Riley
