1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year => 1964 1/2 - 1965 => Topic started by: G Wood on December 08, 2019, 12:00:01 PM
Title: 65 SJ Underdash Wire Harness Bracket
Post by: G Wood on December 08, 2019, 12:00:01 PM
I know the bracket is located underdash but i cannot locate where. I am re-assembling and I know it supports part of the wiring harness but cannot determine where it mounts. My interior is white, and my bracket is white with a rubber covering on the hook portion. Any of my manuals that I have do not show this. Any help is appreciated.
Title: Re: 65 SJ Underdash Wire Harness Bracket
Post by: jwc66k on December 08, 2019, 01:28:57 PM
The only one I can remember is attached to the vent, but not with the hardware you show. Convertibles use two "similar" for the top electrical stuff.
Do you have the 65 Osborn Mustang Electrical Assembly manual?
Post by: Coralsnake on December 08, 2019, 01:52:40 PM
On the side of the pedal support?
Post by: G Wood on December 08, 2019, 02:20:28 PM
It is not on my vent as the holder for my flasher is mounted there. Which side of the brake pedal support does it go? I think that it supports the harness from the steering column where it exits the column. I will look again if I am overlooking the mounting hole.
Post by: Brian Conway on December 08, 2019, 02:58:38 PM
Picture of my 65 vent showing flasher-harness brackets and fresh air pull.  Brian
Post by: G Wood on December 08, 2019, 03:10:55 PM
Thanks Brian, I will relook at my vent as i may have overlooked a mounting hole in the cannister.
Post by: G Wood on December 08, 2019, 04:41:17 PM
This photo is similar to the manual but I do not have another drilled hole in my air vent. I have it out of the car and there is only the flasher bracket on the backside anď no other holes.
Post by: CharlesTurner on December 08, 2019, 10:49:32 PM
It goes on the bottom edge of the dash, to the left of where the parking brake handle assy attaches.  The screw goes up, nut on the back, the bracket edge is on the bottom of the dash... so it attaches screw into bracket, bracket on dash, nut on the back.
Believe this might be a San Jose detail or maybe other plants followed the same and eventually went to installing it on the fresh air vent.
Post by: CharlesTurner on December 08, 2019, 10:55:10 PM
Pic from October '64 SJ car.
Post by: jwc66k on December 09, 2019, 12:36:40 AM
The 64 Electrical Manual (AM0003, pg 13) show the bracket, 370805-S100, attached by a hex head sheet metal screw (42127-S8) to a "lip" on the upper LH dash above the fuse block used for the main under dash harness.
The 65 Electrical Manual (AM0008, pg 23) shows the same bracket attached by a pan head sheet metal screw (358735-S2) to the upper rear portion of the LH vent used for the turn signal harness up the steering column. No effective dates are visible on either page.
The lower LH edge of the dash location by the parking brake, is very possible given the hardware shown in the original post. There obviously is a build time, early 65, and plant specific, San Jose, for this application. That is stated so as to warn others to ask.
Post by: G Wood on December 09, 2019, 09:13:04 AM
Thanks very much
Post by: ChrisV289 on December 09, 2019, 09:25:39 PM
So based on Charles’ pic I went looking for mine and it would appear it was there based on the marks (first pic, honey gold). My blue fastback has it attached to the fresh air vent piece (second pic). Now I need to go poke around my friend’s shop and find one.  Charles or Jim, any idea what bolt/screw that is holding it?  Doesn't look like the one you mention in your reply Jim based on AMK.  ALmost looks like the screw/bolt that holds the corral bars to the grill
Post by: CharlesTurner on December 09, 2019, 10:11:58 PM
The screw looks like what attaches a 65 horizontal grille bar to the grille, except it's zinc plated, not phosphate.  The nut is like used on the tail light bucket to body.
Post by: jwc66k on December 10, 2019, 12:35:38 PM
Based on Charles observation, I determined that the screw is Ford p/n 375922-S7, and the nut is Ford p/n 359606-S8. Both are 10-24 thread. The screw is the same that is used on the 65 glove box door hinge including finish (finish -S7 only for 1965).
Post by: PraireBronze on December 10, 2019, 12:58:03 PM
For what it's worth, mine was and is attached to the fresh air vent.
Post by: ChrisV289 on January 01, 2020, 04:34:15 PM
So I was able to get two of these and clean them up. Were there any stampings found? I found this on both of them
