1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year => 1968 Mustang => Topic started by: bullitt68 on March 08, 2020, 06:23:14 PM
Title: 1968 San Jose GT 390 Front Rotors
Post by: bullitt68 on March 08, 2020, 06:23:14 PM
Just curious as I hadn't noticed before, but I have two different rotors. Not sure what they are different. No markings or stamps anywhere. I believe that my car should also have the 2 pce rotors. Do the factory rotors have markings and stamps? A reference photo would be great.
Title: Re: 1968 San Jose GT 390 Front Rotors
Post by: J_Speegle on March 08, 2020, 07:55:13 PM
Easy to see that you have at least one replacement rotor. Will see if I've got some examples to share. Don't recall many pretty pictures of the detail though  ::)
Know there are at least a couple of versions of the rotors installed on 69 cars. Not sure if that is tied to the car assembly plant and in turn the different suppliers or something else.
Post by: Bossbill on March 08, 2020, 08:09:24 PM
The replacement rotor is the one piece looking affair. Your pic 2 & 4.
I believe the 68 rotors are similar to 67s with a few differences.
The 68 original assembly rotors have a square cutout in the hub face along with a drilled hole like 67. Rather than having windows in the rotor portion like 67, the windows are gone and are solid. Also, the thickness and throwaway dimension is different between the two.
Here are a few pics of what I'm told are original 68 assembly line rotors.
Post by: bullitt68 on March 09, 2020, 01:11:38 AM
Thanks Jeff. If the photo in 2 & 4 are the replacement rotors what rotors are in photo 1 & 3. In the photos your posted, are those what they refer to as 2 piece rotors, or was that just 1967.
Post by: Bob Gaines on March 09, 2020, 02:29:16 AM
Rotors in pic 1 and 3 are the 2 piece style rotors. The 2 pc style rotors were typical on 65 on up through the 70's Mustangs . Even replacements were typically 2 pc style up until the 90's when the more cost efficient on piece style came into mainstream use.
Post by: bullitt68 on March 09, 2020, 02:46:42 AM
Thanks Bob. So are you saying that the rotor in photo 1&3 is correct for my car or a replacement versions of the 2 piece original one in Jeffs' photos. The one in Jeff's photo look like 2 pieces while the version I have appear to be one piece, but I have never tried to take them apart
Post by: Bob Gaines on March 09, 2020, 03:07:18 AM
The ones in your pic 1 and 3 are definitely 2 pc rotors. They may be service or after market replacements but still 2 pc and more like the factory. The ones in BILL's photos are what the assemblyline typically look like . 2 pc are like the factory the one piece are not. With that said you are better off with some kind of 2 piece rotor compared to the one piece style from a originality stand point and given the expectations you have shared. Another way of saying it is find a pair of 2 piece matching rotors and be done so as to move on to your next issue IMHO . With all do respect you have a lot on your plate and a lot of issues.
Post by: bullitt68 on March 09, 2020, 03:41:47 AM
Thanks Bob. As always appreciate all your advice and feedback
Post by: Bossbill on March 09, 2020, 08:55:17 PM
Were these 2 piece rotors on your car?
I stole this from VMF:
New rotor thickness for 67 is .810 in and minimum thickness is .780 in.
New rotor thickness for 68 and up is .935 in and minimum thickness is .875 in.
If the rotors are at or past minimum NPD has 65-67, but not 68-up except in the one piece.
Post by: bullitt68 on March 09, 2020, 08:57:15 PM
Thanks Bill appreciate it
Post by: bullitt68 on March 11, 2020, 03:06:47 AM
Hi Bill Both these rotors came on my car. I measured them and they must be pretty new judging by the thickness.
Post by: Bossbill on March 11, 2020, 04:37:20 PM
Great news on the two piece.
Not sure what you want to do with the one piece.
Post by: bullitt68 on March 11, 2020, 06:04:28 PM
Well in a perfect world I can find another two piece rotor somewhere. Otherwise I will need to find a new pair somewhere
Post by: Bossbill on March 11, 2020, 06:08:46 PM
NPD part number 1192-A is a one piece replacement.
It should match yours.
If it doesn't match 100% looks-wise just buy both for $106.
Post by: bullitt68 on March 11, 2020, 06:10:24 PM
Sorry that was a typo meant to say two piece rotor, which would be more correct if I can't find original/correct two piece rotors
Post by: J_Speegle on March 11, 2020, 07:41:27 PM
As always you want to cast a wide net when looking for a part like this. The rotors were shared with many other Ford products and sometimes there are fewer people looking for them in those sites and communities since often not as many of those owners care about being original or willing to swap out for a new aftermarket
Post by: bullitt68 on March 11, 2020, 11:25:20 PM
Great point Jeff. I will continue to expand my search. Is there a list or way to know which aftermarket parts are acceptable or recommended vs parts that need to be original.
Obviously some original parts are very hard to come by, unless you find NOS parts for things Like: Exhaust, Brake Pads, Oil & Air Filters, Spark Plugs etc. Some of these parts may be too expensive or hard to locate for some. Obviously there are lots of people who are opting for new aftermarket parts for some of these reasons
Post by: Bob Gaines on March 12, 2020, 02:12:23 AM
Fortunately there are good reproductions here now and other new ones entering the market all of the time for some items like exhaust, oil filters.The appearance of many after market brake pads can be modified to look like assemblyline once installed. Chris Brown is coming out with a excellent repro of the C7 / FA41 assemblyline air filter for example. Genuine Autolite BF42 sparkplugs are still relatively plentiful and obtainable .
Post by: bullitt68 on March 12, 2020, 02:14:19 AM
Thanks Bob that is great news
Post by: 1967 eight barrel on March 12, 2020, 02:45:47 AM
Raybestos still makes the two-piece rotor.
Post by: bullitt68 on March 12, 2020, 03:45:51 AM
Thanks I went to the website which rotors were you referring to
Post by: 1967 eight barrel on March 12, 2020, 04:47:41 AM
I'd have to go look at my receipts. It's been a while. You will have to pull the studs back in to retain the hubs.
