1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year => 1964 1/2 - 1965 => Topic started by: ChrisV289 on March 30, 2020, 10:45:39 PM
What is the correct carburetor stud length for a 66 Hertz automatic (autolite 4100)?
Same as the 4 speed.
Does it use the same as the standard intake and carb setup? NPD and Virginia Mustang both carry various lengths
I am not as familiar with regular Mustangs as I am with Shelby's. I believe the regular Mustang cast iron intake used a spacer which the the Shelby did not. I have always gotten the studs when I needed them from AMK . I don't remember how they were listed but it must have been easy to find as I don't recall a issue in finding them. Maybe a 65-70 GT350 intake stud kit or something like that . Once the stud is threaded into the intake the stud stands approximately 1 inch tall .
Sorry don't have any Mustang ones out and not a single cast iron intake to remove one for you :( Hopefully someone else will to help you out
Chris : If the Hertz uses a 1" spacer, like the other 1966 A and K codes, the correct studs are as follows :
Part # 88471-S ; overall length = 2-1/2" ; 1/2" of 5/16-18 thread ; 5/8" of 5/16-24 thread. Picture attached.
None of the Reproductions I have seen are technically correct, as the lengths of thread are incorrect. However, once installed, who will know.
Hope this helps.
Hope this helps.
Hertz or other 66 auto GT350 does not use a spacer as I already mentioned in Reply # 3 .
