1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year => 1970 Mustang => Topic started by: ng8264723 on April 14, 2020, 01:05:11 AM
Title: 1970 428 CJ mount mount color Are they black?
Post by: ng8264723 on April 14, 2020, 01:05:11 AM
I thought the frame mounts were black and the isolators (rubber) were black and the engine bracket bare steel.  Is this correct?
Title: Re: 1970 428 CJ mount mount color Are they black?
Post by: Bob Gaines on April 14, 2020, 02:22:09 AM
For 70 the frame mounts are black .69 were bare steel.
Post by: J_Speegle on April 14, 2020, 03:09:59 PM
There are a number of tear  down pictures of a 70 Dearborn built CJ convertible in the Unrestored picture thread section here is a picture from that thread showing that the frame part of the mount - made up of two sections - was both black and natural
Hope this helps. May want to check out the tread for some additional details. and a few more pictures of the mounts ;)
EC-3 Frame mount for engine. Semi-gloss black with bare steel lower base brackets
(http://www.concoursmustang.com/forum/gallery/11/6-150918171913.jpeg)
Post by: ng8264723 on April 14, 2020, 08:16:23 PM
Jeff,
I did see that pic.  I can't find the engine side............
Any idea on z-bar clutch rod?
Post by: 1970 Snake on April 18, 2020, 12:39:06 PM
This topic is of interest to me because of what I found during my 1970 428CJ disassembly. The mounts where semi-gloss black, but the side clamp brackets where plated in yellow zinc before install, then possibly painted before the rubber motor mounts where installed. Additionally the mounts had color coding for the LS and RS mounts "under" the side clamp brackets, perfectly preserving the color coding. See attached pics
Also of interest where  the trap door hinges which where also yellow zinc plated before install. See attached pics
I decided to reproduce these finished to the original findings on my car.
Hope this also helps with some input on this topic
Post by: J_Speegle on April 18, 2020, 06:19:08 PM
Have some examples with white markings on the frame mount on both sides of the engine compartment. Since these were shared with many other engine combinations there are allot more examples of them than the engine side of the mounts
Post by: ng8264723 on April 18, 2020, 09:27:09 PM
I guess I will do black.  It sounds like some were black and in Ma it will help with the inevitable rust!
Post by: specialed on April 19, 2020, 12:12:11 PM
The 70 side L shaped engine frame brackets were yellow zinc and the one side has a big R stamped in it unlike the 67-69 L brackets that were bare steel.
Post by: 1970 Snake on April 19, 2020, 01:09:49 PM
Excellent that's good news, that I do have it right based on the findings on my car. The middle picture in my previous post is my finished DS assembly, with the mount bracket semi-gloss black, the L bracket yellow zinc, and all the bolts and nuts phosphate and oil and the motor mount is NOS which I purchased over 25 years ago. The PS is the same. Also the engine brackets are bare metal with phosphate and oil bolts and washers also. And you are correct regarding the R marking, its on the PS mount, Thanks.
Post by: specialed on April 19, 2020, 03:16:54 PM
Look at the L shaped side bracket for the 70 type R stamped .
Post by: 1970 Snake on April 19, 2020, 04:52:42 PM
Yup got it, unfortunately 50 year old pieces with some corrosion don't show up as shiny when re-plated, but the plating still covers well, see attached
