1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year => 1967 Mustang => Topic started by: tgilliam on May 03, 2020, 01:08:03 PM
Title: 1967 Mustang Emergency Brake Handle Assembly
Post by: tgilliam on May 03, 2020, 01:08:03 PM
Looking for how the "H" shaped detent & spring go into the body of the E-Brake handle body. This fell out while I was cleaning it up before I could see exactly how it goes together. Any help or a detailed picture would be a tremendous help and appreciated. Thanks in advance.
Tom Gilliam
tom@jtgil.com
Title: Re: 1967 Mustang Emergency Brake Handle Assembly
Post by: 67gtasanjose on May 03, 2020, 08:55:47 PM
Here, these should help
Post by: tgilliam on May 03, 2020, 10:14:00 PM
Richard, Thanks a million. That is exactly what I was talking about. In your third picture, is that the short end of the spring that can be seen sticking out by the ear on the detent? I appreciate you taking time to get these pictures and post them.
Tom Gilliam
tom@jtgil.com
Post by: 67gtasanjose on May 04, 2020, 04:58:06 AM
Tom Gilliam
tom@jtgil.com
I took these apart for replating the parts a few weeks ago so these were to be my reassembly images. I figured these were all I needed but without the pieces in my hands (pieces are away at the replater service), I cannot answer your question.
Post by: Blue_67_Fastback on May 05, 2020, 02:50:37 AM
Hallo Tom,
i rebuild mine two years ago and had the same problem… the short end of the spring goes to the H-detent, the long one towards the handle. It will “push” the detent down so it engages with the saw-tooth of the handle when pulling out.
You can easily check the function without cables and Installation.
enno
Post by: tgilliam on May 05, 2020, 06:38:58 PM
Blu_67_Fastback,
Thank you for the follow-up information and pictures. I can see the "long tail" of the spring clearly in your pictures. I believe that will help me get mind back in the correct operating position.
Tom Gilliam
tom@jtgil.com
Post by: kkupec02 on May 07, 2020, 12:16:54 AM
How do you get the handle off? Do you drill out the pin?
Post by: RoyceP on May 07, 2020, 12:40:46 PM
To remove the handle I use vice grips on the plastic to bust it away revealing the metal assembly below. Then I pry the metal tube off the stalk leaving the rivet in place. With the metal part out of the way you can grasp the pin with vice grips an pull it out. That way the hole is undamaged by drill bits.
Post by: tgilliam on May 07, 2020, 09:32:27 PM
My experience was - When you break the plastic off the metal tube of the handle, I found the hole in the handle goes all the way through. The pin can be driven out from the opposite side.
Tom Gilliam
Post by: bullitt68 on May 08, 2020, 02:24:44 AM
Hallo Tom,
enno
Thanks for posting ENNO. Are all your parts original?
Post by: tgilliam on May 10, 2020, 11:55:30 AM
Good Day bullitt68,
I believe the unit I am working on was the original assembly line handle assembly.
Tom Gilliam
Post by: bullitt68 on May 10, 2020, 09:03:07 PM
Good Day bullitt68,
Tom Gilliam
It looks like it was in great shape
Post by: Blue_67_Fastback on May 11, 2020, 02:31:14 AM
Yes, it should be.
It has the "FoMoCo" Logo stamped on the side of the handle.
Post by: bullitt68 on May 11, 2020, 03:03:25 AM
Yes, it should be.
Nice. Mine does not appear to have a FoMoCo stamp. I thought it was original until now. I wonder if any originals did not have a stamp or should I start assuming mine is not original
Post by: 67gtasanjose on June 16, 2020, 11:00:42 AM
This spring at the cable attaching point, how does it go back?
(My service manual is at home, if it even shows any help).
Post by: 67gtasanjose on June 16, 2020, 03:26:24 PM
This is my best guess...certainly, I cannot be travelling on a dry and dusty road alone!
Post by: krelboyne on June 16, 2020, 03:36:11 PM
Have not seen that keeper on any of the OEM emergency brake assemblies that I have repaired for the shop. Service replacement maybe?
Post by: 67gtasanjose on June 16, 2020, 04:18:17 PM
Interesting...
I took two apart and found this spring clip, but ONLY ONE in the "pile" of parts (see attached picture taken several months ago, it is in there). I have no pictures of it in place at disassembling either. Just crap off the shop floor? It fits in there so much exact in size and all. Maybe I am on a dry and dusty road all alone!
Both assemblies I have are original equipment units with the block letter FoMoCo stamps.
Post by: Bossbill on June 16, 2020, 04:43:06 PM
I have what appears to be a 68 PB mech. and it's not the same as the 67.
When installed in the floor/firewall, which direction are the captive studs?
Vertical or horizontal?
Post by: 67gtasanjose on June 17, 2020, 04:48:35 PM
So....today, I do a brake job on a 2015 Caravan and look at what it has attached to the brake pad shims...
...does it look familiar?
No coincidences in life, this is my creator (along with Scott's comment) that helps put my mind out of "spin cycle"!
Carry on folks, nothing to see here  ::)
Post by: mustang52 on August 06, 2022, 08:40:16 PM
I'm trying to install the parking brake handle assembly on my 67 mused convertible. The only problem is I can't get the cable ball to go into the inner shaft on the parking brake handle assembly. I read on another forum that you have to remove the pin on the inner shaft of the parking brake handle assembly to be able to install the cable ball into the shaft. I tried to remove the pin but it wouldn't budge. Is this information accurate that. the pin has to be removed? If so, any suggestions on how to remove the pin?.
thank you
Mustang 32
Post by: RoyceP on August 06, 2022, 10:08:12 PM
Yes the pin has to be removed. The factory provided a hole behind it so you can easily punch it out. Installation is just as easy, use a small hammer.
Post by: J_Speegle on August 07, 2022, 12:01:24 AM
Here is another earlier thread that covers the same subject. Going to merge this one and that one to keep them together
https://www.concoursmustang.com/forum/index.php?topic=22378.msg140550#msg140550 (https://www.concoursmustang.com/forum/index.php?topic=22378.msg140550#msg140550)
