1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year => 1967 Mustang => Topic started by: rocnhrse on July 02, 2020, 05:27:23 PM
Rear Applique color
I was wondering if anyone had a modern paint code for the rear applique
I have 2 older paint codes
PPG/DITZLER 326000,DARK GRAY POLY
DARK GRAY METALLIC, CODE5
ARGO 1988,
the paint shop I deal with can't cross reference these codes, any suggestions where to go from here?
First thing, and maybe part of your problem, is that you need to get the Code correct. It is "AR60 1988", not ARGO 1988. Next, you will note that it is "AR", which stands for Lacquer paint. I believe that Ford used the Lacquer, not rubbed out or polished, so it would stand out from the glossy Acrylic Enamel finish that the cars were painted. As it is very hard to find someone that still does lacquer, you will probably have to settle for Acrylic Enamel. I gave my paint jobber the Ford Code,m and he mixed it right up. He then sold me a small can of dull coat to mix with it to remove the gloss.
If you don't want to go that route. SEM makes a spray paint that is very close to the original, just not quite as much metallic in it, and a little darker (SEM Dark Titanium Metallic, Part # 39263).
I have attached a couple of pictures showing the two colors. Note that on the sample based on the Ford Code, I just brushed it on, not wanting to mix and waste my high dollar pint of original.
Hope this helps.
Bob
Also that paint code is not for the lower back panel grille, technically. It is for the rear of the car within the boundaries of the bright trim on the deck lid and quarter panel extensions of the top and sides, and the bumper on the bottom. If the car had the two tone paint option plus the lower back panel grilles, the grilles would also be gray. There are other posts with pictures that you can search for.
Good point John. I should have explained that as well.
Bob
Thanks for the help,I did as much research as I could find in the information given in this site, but was not aware the the painted section at the rear was a different color than the grey aluminum finned pieces . what would be that paint code for the aluminum piece
My goal is to have the way it originally have been done by Ford ,with the 2 paint codes and a rear applique
http://www.concoursmustang.com/forum/index.php?topic=11983.15
First thank you for the effort you put into your research on the rear ribbed panel, I have read it several times trying to get it all straight in my head,I re read your post to me and now I see my answer
If you ordered rear panel painted,and ordered the ribbed panel as well, it would all be the same color ,grey,if you ordered a single color on your car with the ribbed panel it would be body color
I am also assuming that any attaching hard ware is not available and you find what looks the closest to original, btw interesting hobby we got ourselves in to
