1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year => 1967 Mustang => Topic started by: 2V8s on January 25, 2011, 12:31:26 PM
I took my door cards off the other day as I had noticed the upper inside surfaces were quite rusty (aparently this is common as they were bare metal in these areas?).
I took some photos thought they might be useful - I was impressed what good order the doors were in, particularly along the bottoms.
Im interested to know though in what order paint was applied here to the inside off doors - there is what appears to be possible exterior colour underneath the water shield, but then the water shield is black accross its face. Is it normal for these to be painted like this? (it is unpainted on the inside surface).
oh and here's the ones of the water shield which I assume should not have been painted?
Dang! I wish I could find (2) 66 doors that look that perfect. That rust on the inside is best described as surface rust.
Now about painting. My feeling is that any exterior color that found it's way to the inside of the doors was due to overspray by the guy holding the paintgun on the assembly line.
The doors were hanging on the car when painted and the painter had to point the gun so all the right surfaces got paint. I am sure some of those movements directed the spray where some color could get inside the doors. Purely accidental I'm sure.
The "PRO'S" on here can correct me if I'm wrong but I'm pretty sure interior color was sprayed AFTER exterior color and BEFORE the water shields were installed.
Actually, that watershield is installed backwards. The black water resistent side should be towards the door internals and the paper side should be against the door panel. And by the looks of it, it may not be original (any water on the paper side will leave a stain).
The long held belief as confirmed by many unrestored Mustangs and by Jeff's ginormous gallery of pictures is that after primer, the interior colr was applied prior to the exterior color. Nothing was assembled on the door during painting; however masks were used between the painting steps (masked exterior doors, etc. during interior paint; masked interior painted sheet metal during exterior paint). It is quite possible that the center of the interior part of the door where the door panel would go was not masked, thus some exterior color showing there.
Regards,
Pete Morgan
Well there's the facts and now we know. Thanks.
Unlike the "expensive cars" made by Ford those years the cheaper cars were not dipped in primer but instead sprayed leaving many of the unseen surfaces with no paint or a light coat of overspray - later to be replaced by surface rust or worst.
As Pete mention they were mounted to the unibody, primered, sprayed with interior color, then a mask was applied followed by the application of the exterior body color
+2 when you paint a car in this order you understand how much more efficent it actually is not dragging guns and hoses inside a freshly painted car
Don't want to distract from this thread -but this is what was inside my door !
(http://i38.photobucket.com/albums/e136/svo2scj/000_0011.jpg)
Mark
P.S. Some of the lizards are pretty big in AZ !
