Restoring - General discussions that span across many different groups of years and models => Misc Items => Topic started by: Jondors on November 22, 2020, 01:49:53 PM
Title: Front Tie Downs
Post by: Jondors on November 22, 2020, 01:49:53 PM
I know about the rear tie down brackets, but where was the front of the car tied down for shipping to the dealerships?
Title: Re: Front Tie Downs
Post by: Bob Gaines on November 22, 2020, 02:11:19 PM
It is typically called a J hook and it inserted in the oblong key way in the front frame rail.
Post by: jwc66k on November 22, 2020, 05:34:53 PM
Bob,
The picture you included has the caption of "t-hook", which is what we've always called them.
Post by: Bob Gaines on November 22, 2020, 06:07:23 PM
Bob,
I am aware of the other name. There is also a R hook. J hook is what I have always heard them generically referred to as is why I choose to continue calling it that . In conversations with others over the years that is what they are referred to as so apparently it is a accepted generic alternative name in more then one circle.  You can call them whatever you want if it bothers your sensibilities.  Online they are often listed as a J hook cluster which includes the several different versions on a ring that tow truck drivers carry. That apparently confirms that I am not the only one referring to it generically as such. Regardless the picture shows what manner of shape it is .
Post by: jwc66k on November 22, 2020, 06:45:45 PM
The same style "hook" (pick a letter) was used at the rear as well, in the oval slot in the "removable" tie down brackets. I guess the general idea was to securely tie down cars (trucks too) in transit with a universal hook and chain.
Post by: Bob Gaines on November 22, 2020, 07:18:13 PM
+1 . I haven't heard of factory driver stories but I have seen some horrific aftermath of regular tow truck drivers getting over zealous in tightening down the hooks leaving a many inch long ripped gash from the hook tearing through the frame rail metal.
Post by: J_Speegle on November 22, 2020, 07:43:39 PM
Hooks and related details are available in a number of prior threads - found one using the words "shipping hooks"
http://www.concoursmustang.com/forum/index.php?topic=10470.msg62640#msg62640 (http://www.concoursmustang.com/forum/index.php?topic=10470.msg62640#msg62640)
Post by: 67gtasanjose on November 22, 2020, 08:40:19 PM
Bob,
I am aware of the other name. There is also a R hook. J hook is what I have always heard them generically referred to as is why I choose to continue calling it that . In conversations with others over the years that is what they are referred to as so apparently it is a accepted generic alternative name in more then one circle.  You can call them whatever you want if it bothers your sensibilities.  Online they are often listed as a J hook cluster which includes the several different versions...
Attached is a picture of a typical  "RTJ Cluster" used on towing trucks and cargo trailers.
Personally, having driven tow trucks... many names are indeed used, and often based upon geographic areas as well (think "dialect") I am sure...
... in my neck of the woods, the "J Hook" is a really large J-shaped hook that could hook around an axle housing and usually on its own chain or paired with another large J-shaped hook on a sling with a center ring.(to hook twice to the forwards or rearwards tie-down).
In towing, I usually didn't use any other hook except this large J-hook ot sometimes, what I called a T-hook (either one or the other).
This cluster pictured represents IMHO, each "letter-shaped hook" found on what at least this one SELLER calls an RTJ Cluster. Personal choice, I am sure but I will call the hooks by their "letter shape".
Post by: bgp429 on November 23, 2020, 09:47:15 PM
I was in the towing business.  During the 60's - 80's a J hook around the axle and chain to the sling was secure and fast. During that era T hooks weren't sold to the towing industry. I doubt the slots on many vehicles would lock a T in for a horizontal  attachment.   Later on [90's] when rollbacks became available the trucks were equipped with cluster assemblies.  Sometimes T hooks were used on rollbacks if there was spoiler or valance interference but mostly J hooks or chain on all 4 corners.
With car suspensions being more fragile and no steel bumpers neither are recommended today.
We also towed many new cars from rail yards that had T hooks torn out of the frame during transport. The damage had to be fixed before the vehicle could be sold.
Post by: ExportMach on December 10, 2020, 11:19:58 AM
As Im sure MCA members are aware, there is a story in this months Mustang Times about this topic.
Post by: Crgjohnson on December 15, 2020, 09:35:27 PM
The hooks are available from Mac's Tiedown
https://www.macscustomtiedowns.com/products/forged-t-hook-340003?_pos=1&_sid=c43924300&_ss=r
Craig
