1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year => 1967 Mustang => Topic started by: rocnhrse on December 22, 2020, 08:04:06 PM
The grounding cable at the back of right side of engine I thought was screwed to the fire wall,and yet there is no evidence that it was done,any chance it was grounded to one of the bolts that hold the blower motor
It was grounded to the firewall to the right of the blower motor.
Thanks for the picture
Attached from the 1967 Electrical Assembly Manual.
Bob
At the firewall it calls for a zinc dicromate locking washer for good ground connection and a sheet metal screw like used on the regulator or solenoid .I have seen them both silver and gold although I think that the assemblyline manual indicates gold.
Gold zinc (its commonly used name here in the Hi-Tech Silicon Valley) was supposed to make a better electrical connection than clear zinc (another common phrase here), but that has been disputed by some electronic/electrical "experts". The use may be as simple as the use of red dye on bolts - to indicate something other than ordinary.
Bob G is correct. The Assembly Manual shows all 4 pieces of Hardware as having an S36 Finish - Zinc Plate and Dichromate.
I have attached details of the 4 pieces of Hardware from the Ford Standard and Utility Parts Catalog (except for the 34942 External Lock Washer which did not appear in any S&UPC from 1961 through 1975, but shows up in AMK's Guide to Ford Fasteners). Note that as the S&UPC's are Service Parts, all appear with either a Zinc, or Cad Finish. However, to be "Concourse (Assembly Line) Correct", all should be the Zinc-Dichromate Finish as previously noted.
Also of interest to those inquiring minds, yes, the 390's are shown to use the same attaching Hardware. The 6 Cylinder Engine used the most inboard Starter Motor Bolt on the "engine side", and on the "firewall (dash) side", the Assembly Manual does not detail what was used. However, I would guess that it's a "pretty good bet" that the same Hardware was used to attach the cable to the firewall as the V8's did.
Hope this helps.
Bob
