1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year => 1967 Mustang => Topic started by: 1967FEGT on December 22, 2020, 11:29:53 PM
Title: A/C Vacuum Mode Control Valve Failure.
Post by: 1967FEGT on December 22, 2020, 11:29:53 PM
Are leaking AC Mode control valve failures common?  What are the symptoms?
Title: Re: A/C Vacuum Mode Control Valve Failure.
Post by: TLea on December 23, 2020, 09:13:31 AM
Is this a Mustang or a Shelby?
Post by: 67gta289 on December 23, 2020, 09:26:56 AM
I don't have enough data to know whether or not the term common is appropriate or not.  I think though that if you have a problem, that is a moot point.
Everything can fail, of course.  Given the parts and movement involved, I would think that the most common failure would be that the rubber diaphragm leaks by, resulting in a vacuum leak and "none to partial" stroke.  You might hear the sound of a vacuum leak.
What symptoms are you experiencing?
Sometimes the problem is in the control switch - you can divide and conquer using a vacuum gage.
Post by: 67gta289 on December 23, 2020, 12:20:10 PM
I suspect that the vacuum porting switch in the controller (aka control head) is bad.  Part # C7ZA-19B919-C, picture attached, and not serviced separately.
Post by: 67gta289 on December 23, 2020, 12:23:41 PM
I should note that I have these pictures because I have a friend (me lol) that installed this, and followed up with a functional test using a vacuum pump.  I had a similar failure - a few actuators would move, but not all.  Then out is came and I bench tested the head and found it faulty (vacuum not applied to the correct ports as noted in the shop manual).  I have a couple extra units - too pitted up front to go on a car, but as is often the case the party out back was good, so I was able to move the ugly duckling head unit vacuum porting switch over to the nice one.  It bench tested ok (fool me once...) and went in the car, where a fully functional test proved everything out.
Post by: jwc66k on December 23, 2020, 12:42:37 PM
Along with a vacuum pump. (Which also works very well for bleeding brakes, and checking out distributor diaphragms.)
Post by: 67gtasanjose on December 23, 2020, 02:13:47 PM
The vacuum switch disassembles and usually is repairable in my experience.
I also found "just the switch" new before and have one for backup if ever needed.it
Post by: J_Speegle on December 23, 2020, 04:53:55 PM
Parts available for the rebuild?  Think my 71 has a leak it its control valve. Not looking forward to getting to it but could be worst
Post by: Bob Gaines on December 23, 2020, 04:59:27 PM
This reads eerily similar to my experience. I am glad I am not alone. ;)
Post by: 67gtasanjose on December 23, 2020, 05:03:26 PM
I cannot speak of any parts, I took my 67 valve apart, cleaned the mating surfaces, lubricated, reassembled and it quit leaking...soon afterwards, a NOS service part showed up and I bought it too. The repaired one was still not leaking this fall when I put the car together, it had sat 3-4 years boxed and waiting...I wondered if it might leak because no parts were changed out (just cleaned/lubricated) so was half expecting trouble but no such drama.
Post by: 1967FEGT on December 24, 2020, 12:58:25 AM
I used my hand pump and pulled down enough vacuum in the reservoir to show 20 in on the gauge on the Mightyvac.  I couldn't get any of the vacuum motors to work with the switch. They all work fine with the MightyVac.
Post by: ruppstang on December 24, 2020, 09:43:02 AM
If you need a different switch I have one. PM me
Post by: 67gtasanjose on December 24, 2020, 01:05:25 PM
Try taking the valve off the controller assembly, un-do the spiral spring carefully to take it apart. Clean, lubricate. Check for any blockage or internal corrosion and reassemble.
Be sure you have the hose routing correct and it should work or if unrepairable problems are discovered, take Marty up on his offer.
