1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year => 1970 Mustang => Topic started by: alanmac on March 20, 2021, 07:57:19 PM
Title: Wire Harness Retainer clips
Post by: alanmac on March 20, 2021, 07:57:19 PM
Hi I am missing the round retainer clip Item #8 on page 5 (drawing E0-115-1) of the Jim Osborn electrical assembly manual.  The (2) clips are mounted in holes located in front of the right shock tower and below the regulator.  The manual lists three part numbers.  383207-s, 38477-s, 383104-s.  Which part number is correct?  Does anyone reproduce these?  Alan
Title: Re: Wire Harness Retainer clips
Post by: tim_morrison82 on March 20, 2021, 11:07:26 PM
It looks like amk do it. If you can't find original.
https://www.npdlink.com/search/products?search_terms=Amk%2B383207&top_parent=0&year=
Post by: jwc66k on March 21, 2021, 12:36:28 AM
Part number 383104-S is item 9, and does not apply. Your part number 38477-s is written 383477-S and is the standard clip with a wire capacity of 0.62 inch.
Part number 373207-S is for a "Regular Production Option" (R. P. O.) with a wire capacity of 1.0 inch.
There are actually 4, two additional clips are on the underside of the right hand shock tower to firewall brace as item 8. Match them to the dimensions listed above.
Post by: alanmac on March 21, 2021, 01:27:57 PM
Thanks for the feedback.  I have the 1" retainers.  I am looking for (2) of the .62 diameter retainers.  I believe its reproduced as AMK F-417.  Now I can't find a seller.   Alan
Post by: jwc66k on March 21, 2021, 02:20:19 PM
All four are the same. You apparently have the assembly manual, it's time to review it.
In any case, both types are available from AMK. Use the Ford Part Number on the AMK website to get the AMK stock number.
Post by: alanmac on March 21, 2021, 04:35:43 PM
I don't need the two retaining clips under the shock tower support.  I just need the two as mentioned.  I used 383207-S since I had them.  Thanks for the feedback.
