1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year => 1964 1/2 - 1965 => Topic started by: fmr187 on May 28, 2021, 08:56:42 PM
Title: door panel clips
Post by: fmr187 on May 28, 2021, 08:56:42 PM
Assembly manuals call for door panel clips with foam on the bottom of the door panel. Why? Are the the foam clips necessary? I ordered some door panels and they came with clips but they are all foamless. How bad would it be to use non foam clips?
Title: Re: door panel clips
Post by: RoyceP on May 28, 2021, 11:29:52 PM
I get sets of those from AMK. They come with the foam. I suspect that, like anything else Ford did, it is there for a very good reason. They used the foam clips for a long time on door panels, well into the 1970's.
Post by: jwc66k on May 29, 2021, 12:33:34 AM
To reduce vibration and the associated noise.
The effective date in the 65 Mustang Interior Assembly Manual (AM0007 pg19) dated 3/23/65 "seems to imply" the foam clip was added about the time the deluxe (pony interior) body was introduced. The change description is not really worded well.
Post by: CharlesTurner on May 29, 2021, 11:35:55 AM
The foam pads on the clips were used from the beginning of production based on cars I have worked on/disassembled.
The deluxe interior clips are different length, which may be the difference seen in the assembly manual.
