1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year => 1968 Mustang => Topic started by: Benstang on July 06, 2021, 04:41:22 PM
Title: C8OF-9510-C 390 carb wrong date?
Post by: Benstang on July 06, 2021, 04:41:22 PM
Hello!
What can be the reason that a 68 390 gt 4 speed carb has got a date code from 1969??:
C8OF-9510-c
List-3795-1
9A4
Title: Re: C8OF-9510-C 390 carb wrong date?
Post by: Bob Gaines on July 06, 2021, 05:57:40 PM
Hello!
C8OF-9510-c
List-3795-1
9A4
It may be service replacement is one reason there may be others.
Post by: Benstang on July 06, 2021, 06:15:28 PM
Ok thanks for the answer.
So It can be a legit 390 gt 68 manual carb.. but I will never be date correct
Post by: J_Speegle on July 06, 2021, 10:27:05 PM
May not apply in this specific case but service replacements (any of them) car be different from the originals. Could be plating, parts shaped differently, different hardware used and so on. Just wanted to remind others of this possibility and to compare and check for the details
Post by: Bob Gaines on July 06, 2021, 11:33:05 PM
The only reason to be concerned about a date code is if you are concerned about originality. With that said the most important thing is that it is the correct carb for the car with correct components. The date code is not considered in concours Trailered Competition and is only a issue in Thoroughbred where the battery ,belts ,tires etc. have to be date code correct too. Nice to have for your own satisfaction however it is secondary to most things as it relates to the cars. For example if you have a car that has been messed with over the years like most have been and many things are not assemblyline correct like non assemblyline workmanship details ,no orange peel slick paint job , replacement tires ,battery, exhaust  etc. then the date code on one item wether it is assemblyline correct or not doesn't mean much in the big picture of the cars originality.
Post by: Benstang on July 14, 2021, 04:49:34 PM
Is it normal that the old holleys had some kind of ball blocking the idle passage or did someone mess with my carb there?
Looks like on one side it is 100% sealed.
Ben
Post by: J_Speegle on July 14, 2021, 05:08:21 PM
Not something I ever recall seeing. Don't have a similar carb handy at the moment
Post by: Benstang on July 14, 2021, 05:15:00 PM
Hmmm seems like someone messed with it..
But I don?t get why you want to restrict or even fully close the idle circuit.
Makes no sense for me.
Ben
Post by: Benstang on July 15, 2021, 05:49:08 AM
These are some sort of idle mix screws...
I have never seen them before.
Does anyone know how to adjust them?
I had problems with my idle mix screws don?t respond proper.
I assume these?base plate idle screws? had been to far in.
Ben
Post by: ruppstang on July 15, 2021, 08:46:20 PM
Our early 68 S code carb has those screws and I could not get it to run correctly so I sent it to a friend in Seattle who is pretty good with carbs and he said the early 68 carbs had those extra mixture screws and that most that
have them run poorly. He said that they are really difficult to get out. When I got my carb back it ran great.
Post by: Benstang on July 16, 2021, 12:32:54 AM
My first thought would be to let the screws out complete and just plug the hole and adjust the idle only with the normal metering block idle screws.
Post by: PacificaXR7GT on July 16, 2021, 02:45:24 AM
I also had this problem with my 68 S code manual carb. I sent it to Rob Campbell and it came back running like a champ.
Post by: Benstang on July 16, 2021, 04:27:15 AM
Long story short answer:
I did open the screws about 4 rotations and closed the hole from outside so that there is no vacuum leak and almost no restriction.
Runs like a champ now..
700 rpm idle 16,5 hg  air fuel ratio around 11  (68 390 gt 4speed)
Carb pulls very strong. Deacceleration popping is gone!
 Thanks guys for your help!
