1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year => 1970 Mustang => Topic started by: Hipo giddyup on November 04, 2021, 01:20:01 PM
Title: Harness routing around the passenger shock tower
Post by: Hipo giddyup on November 04, 2021, 01:20:01 PM
Just as stated in the subject. Looks like there are two harness retainers that hold the harness up on the passenger side shock tower. Since replacing the shock towers with new repros, I no longer have measurements for the new holes on where to drill. Can anyone supply measurements for these? Any reply is greatly appreciated!
Title: Re: Harness routing around the passenger shock tower
Post by: Hipo giddyup on November 08, 2021, 12:16:17 PM
I am seeing these holes on the original shock tower. Can anyone confirm the harness holders would go here?
Thx
Post by: jwc66k on November 08, 2021, 04:03:31 PM
What year?
Post by: jwc66k on November 08, 2021, 06:04:37 PM
Thx
Per the 70 (via your PM) Mustang Electric Assembly Manual (AM0033 pg5) those two holes use 1 each 95832-S strap to hold harness 14401 in place.
Post by: J_Speegle on November 09, 2021, 01:07:12 AM
Thx
(https://www.concoursmustang.com/forum/gallery/16/6-091121000641-163521911.jpeg)
Post by: Hipo giddyup on November 09, 2021, 10:10:58 AM
Yep, a 70' Jim.
Thanks so much to the both of you, as usual!
Post by: Bossbill on November 09, 2021, 11:09:04 AM
Did you get a measurement yet?
Post by: alanmac on November 09, 2021, 02:11:04 PM
Approximate measurements with a two steel rules
referance to the above picture.
front ot shocktower:  from inner fender to center of fastener 2.3"
front ot shocktower:  from top of shocktower with 1/2 wide steel rule on it to the center of the fastener 7.5"
inside of shock tower: from the top of the shocktower with a 1/2 " steel rule flat on the front top at an angle with the edge lined up for a veritcal measurement 1.5"
inside of shock tower: from the front of the shocktower with a 1/2" steel rule lined up with the edge lined up for a horizontal measurment 2.5"
Not easy to measure, the measurments seemed repeatable, but probably +/- .050 to .100, I would have someone repeat my measurments to verifiy.  Alan
Post by: Hipo giddyup on November 09, 2021, 04:52:27 PM
Thanks so much Alan!
