Restoring - General discussions that span across many different groups of years and models => Drivetrain => Topic started by: bburns31 on January 31, 2023, 12:18:17 PM
I am ordering a rebuild kit and want to make sure I have the correct kit. Looking through the library docs, I'm not positive which model I have since mine doesn't have the bump stop on top of the carrier.
My tag indicates WCZ-E is a 2.8 ratio 7 3/4" ring gear dia. Non-locking 28 axle shaft spline
Looking at the rebuild kit options, I'm assuming I go with a 8" kit? The kit I was looking at mentioned a 25 pinion spline count which made me unsure.
Any reassurance you could provide would be me helpful as I'm wading into unknown waters. Is the library doc I've attached correct?
https://www.fordification.com/tech/rearends_ford02.htm
Thanks, John. That is the site I used to identify my model. The 7 3/4" threw me for a loop. Is that considered an 8" diff? I don't see any kits for a 7 3/4".
