Marketplace => Wanted Ads => Topic started by: CharlesTurner on January 06, 2024, 02:33:33 AM
Title: WTB: '68 big block fixed a/c idler pulley
Post by: CharlesTurner on January 06, 2024, 02:33:33 AM
Looking for a good used fixed a/c idler pulley assembly for a '68 390/428.  This is the one that mounts below the compressor.
Original Ford p/n C8AZ-8678-B
*Bought one, thanks
Title: Re: WTB: '68 big block fixed a/c idler pulley
Post by: ruppstang on January 06, 2024, 09:20:20 AM
I have one that is cast and a two hole. I think what you are looking for is pressed steel and three holes?
Post by: CharlesTurner on January 06, 2024, 11:30:08 AM
Should be a 3 hole steel.  I think the 2 hole cast would be for a small block, at least that's what is on a '68 GT350 that I'm working on also.
Post by: Scode67FB on January 07, 2024, 01:47:19 AM
I'm sure I have one of these idlers. I don't know if there are differences between 68, 69 and 70.
Post by: CharlesTurner on January 07, 2024, 02:01:43 AM
68/69 are supposed to be the same
Post by: 67350#1242 on January 07, 2024, 12:17:12 PM
Mansfield shows they have a NOS  C8AZ-8678-B
Post by: Bob Gaines on January 07, 2024, 04:43:30 PM
2 holes cast for a 67 early 68  Big block also and they are easily confused but they are a different shape and will not interchange.
Post by: krelboyne on January 07, 2024, 04:46:25 PM
1968-69 is small, flat bearing. 1970 has a slightly larger, diameter flat bearing. 1970 normally, also has a D0AA.. casting number on it.
Post by: CharlesTurner on January 08, 2024, 12:03:41 PM
I had contacted Bill already, he didn't have any.  Thanks
