1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year => 1968 Mustang => Topic started by: dkknab on July 18, 2024, 05:59:14 PM
Title: 68 Metuchen Accelerator Gas Pedal Screw 9873
Post by: dkknab on July 18, 2024, 05:59:14 PM
I removed (destroyed the head as pictured) my gas pedal screw.  It is a silver color and rusted to the bracket on the underside of the pedal.  I believe the finish is listed as S101. It seems you can only get the S2 P&O finish screw.  What's correct for my car? Small detail but nice to get it right.
Interesting detail though,  when you zoom in on the shaft you see a line and some dark color.  Did my screw loose it's P&O finish over time? The shoulder dark color is rust where the screw bonded with the pedal bracket.
Title: Re: 68 Metuchen Accelerator Gas Pedal Screw 9873
Post by: jwc66k on July 18, 2024, 07:30:06 PM
You neglected to use the Ford part number.
Post by: dkknab on July 18, 2024, 08:19:37 PM
Guilty.  9873 is the number from the assembly manual.  380503-S8 is what I saw in the Hardware spreadsheet and attached picture. S8 being zinc plated which makes sense for silver color.  I don't recall where I saw S101 finish.  Help!
Post by: krelboyne on July 18, 2024, 08:56:32 PM
AMK sells that specialty screw. Part number B-12547,
380503-S2 Phosphate and Oil.
Post by: dkknab on July 18, 2024, 09:17:00 PM
Yes but is that the correct finish? I have what I believe is an original part, pictured previously,  that is not P&O. What's correct?
Post by: jwc66k on July 18, 2024, 11:27:14 PM
Did you look in this forum's library? Try topic "Mustang Hardware Spreadsheet 67-68". There are two files, one by application (use), the other by part number. All entries have the source referenced.
Post by: jwc66k on July 18, 2024, 11:33:28 PM
AMK sells the wrong finish screw. Get a hold of Max and tell him. It's not the first time he's sold hardware with the wrong finish.
Post by: dkknab on July 19, 2024, 08:17:23 AM
I did check both spreadsheets. 380503-S8 is listed as GAS PEDAL-ACCELERATOR ARM but interesting it's only listed for year 67, 68 column is not marked. The finish is of course S8.
And in the AMK Ford fasteners guide page 139 380503 is listed with just S finish so I'm not sure what exact finish from that entry.
I do have 2 screws now,  the first from NPD and the second from Magic Valley Mustang.  The second one is a Scott Drake part and it's P&O so I'll remove the P&O from that one.
PS One other note.  Apparently as of April 25, 1968, the pin screw changed.  I've seen C8OZ-9873-1A being listed and it's a silver pin that looks very different from the one I have.  I've attached a picture from NPD.
Post by: Bob Gaines on July 19, 2024, 11:23:42 AM
I would suggest to do some more research on this finish for confirmation. This conversation has me second guessing myself because I admit I thought 65-68 were all PO. I do know at least for sure some of the years the screw was PO. 68 my be different or it may be a different vendor thing but I would like to hear others input.
Post by: dkknab on July 19, 2024, 11:30:35 AM
Here's again my vote for S8 zinc plate finish and picture of screw I removed with much force.
Post by: jwc66k on July 19, 2024, 12:49:42 PM
That screw is shown in the "1968 Mustang Chassis Assembly Manual" (AM0025) pgs 63 and 64, but with a Ford engineering base number of "9873". The supporting document for "9873" is not readily available so it was not listed in the spreadsheets. In the 1975 edition of "Ford Car Parts" (aka MPC), in the text section 97 page 35, the service replacement for 1968 is 380503-S8 (irony not withstanding). The NPD drawing is very likely based on the Ford drawing so an assembly line part is available. However, the NPD drawing show a different type of drive but without any other details.
There are no finishes listed in the "AMK Guide TO Ford Fasteners" for any specific item. Too many variables.
The -S101 is listed in "Ford Standard And Utility Parts Catalog, January 1969" (AM0205) edition, on page 34, as having a Nylon Insert. Where it is used is not specified.
Post by: Bob Gaines on July 19, 2024, 02:57:38 PM
I would keep that picture compiled in your binder of this cars details to be kept with the car when judging . That way if there is a question the picture will help answer.
Post by: J_Speegle on July 19, 2024, 03:51:36 PM
Depending on where the part was listed the S2 would be the finish but it could be the finish of the service replacement or the original. Example Assembly Manual verse a later MPC. Of course with the assembly manual the finish or part could have been used after the page the information was printed on was replaced or revised
Took a look and because of the location no clear pictures of one installed. Recall looking at a box of service replacement ones years ago but don't know that the finish was correct for a 68 NJ built car
Post by: dkknab on July 19, 2024, 04:33:50 PM
Side by side,  the Scott Drake part (top) is very different from the one I pulled off my car (bottom). The head on the SD part is thinner,  the threads are longer,  and there is the groove on the threads.
Post by: jwc66k on July 19, 2024, 05:32:57 PM
Out of curiosity, what type of drive is on the lower screw, the one you "damaged"?
Post by: J_Speegle on July 19, 2024, 05:34:08 PM
Like so many reproduction but better now then in the past, its likely that the reproduction was copied from a later service part purchased in the 80-90's
Thanks for the side by side
Post by: dkknab on July 19, 2024, 05:34:49 PM
Phillips
I wish I had some patience to figure out where the bolt might have rusted to the pedal and would have not destroyed it.  Oh well.  Maybe I need to get another 68 , I'll know better next time.
Post by: jwc66k on July 19, 2024, 07:00:06 PM
That looks like a Phillips (or a"Posidriv" type -  I almost always use the same type X-Rec screwdriver on either). The drive shown in the NPD drawing looks like a six point, like an Allen screw or one with "points" around the hex (the name escapes me). What you had installed was the 64-67 type, not the C8OZ-9873 (it's missing the "-A" according to the MPC). The NPD screw "may" be the Concourse correct style.
Post by: J_Speegle on July 19, 2024, 07:06:16 PM
Did a little search and came up with this original gas pedal and retainer
Not making any claims just posting it for consideration and discussion  :)
(https://www.concoursmustang.com/forum/gallery/20/6-190724180456-204381139.jpeg)
Post by: dkknab on July 19, 2024, 07:28:38 PM
Apparently there was a change as of April 25, 1968 which my car is before. That's specified in the NPD listing. So yes concours for cars after April 25 1968 possibly,  but not for me.
Post by: dkknab on July 19, 2024, 07:30:56 PM
Looks like mine,  the threads are about the same length as the unthreaded section unlike the Scott Drake part where the threads are longer than unthreated section.
Post by: TLea on September 21, 2024, 09:31:53 PM
I know this is late to the game, but hopefully I had some clarity to this. I have seen both silver and phosphate screws used on original cars from 65 through 68. The majority of them have been phosphate. The one you show from the NPD catalog with the C8 part number is actually used in 69.
