1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year => 1969 Mustang => Topic started by: Stangly on June 04, 2011, 03:27:23 PM
Title: 69 fuel line placement
Post by: Stangly on June 04, 2011, 03:27:23 PM
Does anybody have a photo showing the routing of the fuel line from the tank up and along the frame rail at the rear wheel.  I have it figured out from the front of the car to the last clip where it jogs to the inside of the under carrage right in front of where the front leaf spring attaches.  Does it then run along the inside of the frame rail above the bracket for the E-brake cable? The fuel line I purchased doesn't appear to bent correctly.  Also any suggestions on where to purchase a better replacement line or are most guys bending there own.  The original was a hodge podge of spliced pieces and is of no help.
Title: Re: 69 fuel line placement
Post by: Aussiemach on June 04, 2011, 09:26:51 PM
Hope these help (when looking at the first pic click on previous to see the next one, for some reason they are backwards in order from the gallery)
(http://www.concoursmustang.com/forum/gallery/0/thumb_331-040611191248.jpeg) (http://www.concoursmustang.com/forum/index.php?action=gallery;sa=view;id=404)
(http://www.concoursmustang.com/forum/gallery/0/thumb_331-040611191342.jpeg) (http://www.concoursmustang.com/forum/index.php?action=gallery;sa=view;id=405)
(http://www.concoursmustang.com/forum/gallery/0/thumb_331-040611191656.jpeg) (http://www.concoursmustang.com/forum/index.php?action=gallery;sa=view;id=409)
(http://www.concoursmustang.com/forum/gallery/0/thumb_331-040611191602.jpeg) (http://www.concoursmustang.com/forum/index.php?action=gallery;sa=view;id=408)
(http://www.concoursmustang.com/forum/gallery/0/thumb_331-040611191511.jpeg) (http://www.concoursmustang.com/forum/index.php?action=gallery;sa=view;id=407)
(http://www.concoursmustang.com/forum/gallery/0/thumb_331-040611191438.jpeg) (http://www.concoursmustang.com/forum/index.php?action=gallery;sa=view;id=406)
Post by: Stangly on June 05, 2011, 12:06:31 AM
Thank you so much for the photos.  I think the fuel line bought is not bent incorrectly.  The portion of line that runs from the sill up and over the spring mount is to long.  It goes all the way over to the inner side of the frame rail and over the bracket that holds the emergency brake cable?
Post by: Sluggo on June 07, 2011, 01:29:43 PM
When you set up the gallery you can choose which order for the pictures to be presented. Ascending or decending. You can also choose wheather to order them by date, title, most viewed, etc.
If you choose by date, I believe it uses the time stamp in the exif data to determine the time the picture was taken.
If you want to show a chronology, sort by title and ascending, titling the pics in the order you want them to appear. Using a 5 digit numbering sequence is best for 100 pics or less. Like so: pic00001.jpg, pic00002.jpg, etc.
This is necessary because the directory structure will take pic1, pic2 and place them in order but when you get to pic10 it will place it in front of pic2 because 1 comes before 2. Hope that made sense.
You can edit the gallery any time after you set it up including titles.
