1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year => 1964 1/2 - 1965 => Topic started by: YELLOWBOSS2 on June 09, 2011, 07:47:57 PM
In a 65/289 alternator bolt kit there are three bolts the long one and two short ones and there are only two washers. One larger in diameter and one smaller. Which bolt does the smaller washer go on. I would guess that the larger flat washer goes on the bolt that adjusts the belt tension. Does the smaller one go on the long bolt or the shortbolt that goes through the bracket into the water pump.
Thanks for any any help.
Dave
The washer and lock nut go on the lower adjustment bolt.
