1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year => 1964 1/2 - 1965 => Topic started by: ChrisV289 on August 03, 2012, 01:22:16 AM
Is this the correct thermostat housing for a 65 SJ 289 FB (built 10/1964)?
(http://i99.photobucket.com/albums/l283/shelbee350/Honey%20Gold%20-%20Mine/DSC06019.jpg)
It looks like a 68 version to me .
Here's what's on my June 64 car.
-Chris
[/quote]
That's what I thought, that plug towards the top didn't look right...
The plug is used for an external Temp guage under the dash.. for anyone wondering... Just remove the plug and insert a standard temp sending unit...and voila..instant temp guage.. Summit sells nice 2" and 2 1/4" Autometer temp guages... or just use an old SW - Stewart Warner one from a swap meet..lol...
Tony K.
That's not right. This is a Ford t-stat housing for a later 289/302 with emissions control.
Tony K.
+1 for no temp sender, it was for a temp controlled vacuum switch with ports going to the intake, carb and vacuum advance
Plus the temp sensor should be on the engine side of the thermostat.
Tony K.
The plug is used for the heat activated vacuum swich for the distributor advance curve from the factory. It can be used as you say but most factory and after market aluminum intakes already have a place for a temp sender . I don't know why you would need two?
Chris, if you are a 289 guy and don't have Bob Mannel's book on small block Fords you should. Lots of great info and pictures.
I do need to get that...maybe an early Christmas present to myself...
Good idea. ;)
You'll be -amazed- at the information in the book.
