1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year => 1964 1/2 - 1965 => Topic started by: ChrisV289 on August 04, 2012, 11:49:09 AM
So as I take things apart, I find some things right and some things I question...Below is a pic of a stud...Two of these were holding the power steering pump bracket along with the AC bracket to the front of the block below the valve cover...Are these correct? I have only seen one other car built in San Jose with the same setup as mine around here in AZ and he had the same bolts/studs as well, but I want to make sure it is correct before I put everything back together
(http://i99.photobucket.com/albums/l283/shelbee350/Honey%20Gold%20-%20Mine/IMG-20120804-00575.jpg)
Yep! Correct. Should be 3 I think and during SOME production periods, they have a lock washer under the nut.
