1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year => 1964 1/2 - 1965 => Topic started by: MWM on May 17, 2013, 03:51:11 AM
Title: Four way flasher location
Post by: MWM on May 17, 2013, 03:51:11 AM
When did the switch go from the drivers side to the passenger side?
Title: Re: Four way flasher location
Post by: CharlesTurner on May 17, 2013, 09:48:40 AM
Are you asking about four way emergency flashers in '65 cars?
Post by: MWM on May 17, 2013, 12:25:32 PM
Yes, please. For a 1965. Sorry I omitted that part.
Post by: NEFaurora on May 17, 2013, 08:04:14 PM
Not to hijack a thread here, but since we are on the subject, I'd like to add 4-way flashers to my '65 Standard Convertible.  Outside of locating an original NOS kit off Ebay,  Does anyone have any suggestions???
Tony K.
Post by: midlife on May 17, 2013, 10:04:16 PM
Tony K.
Although not concours-correct, you can add the early 66 e-flasher system to the main harness as a plug-n-play option.  The switch would go in the glove box.  Of about 10 e-flasher switches that have come in, not a single one still works, and it is not being reproduced.  I did find a reasonably close switch that has the proper functionality.  I also have at least 3 or 4 of those harnesses in stock.
Post by: NEFaurora on May 17, 2013, 10:56:45 PM
Midlife,
What about this? Would this work?  Apparently It's new from Drake..
http://www.ebay.com/itm/1965-Early-1966-Mustang-Emergency-Flasher-Switch-WITH-HARNESS-SCOTT-DRAKE-/400478249828?pt=Vintage_Car_Truck_Parts_Accessories&hash=item5d3e5d2364&vxp=mtr#ht_1988wt_1161
Post by: NEFaurora on May 17, 2013, 11:01:17 PM
Here's another...
Can I just plug this into my late '65??
http://www.ebay.com/itm/1965-66-Mustang-Emergency-Flasher-Switch-/110621780755?pt=Motors_Car_Truck_Parts_Accessories&hash=item19c1926b13&vxp=mtr#ht_76wt_1161
Post by: NEFaurora on May 17, 2013, 11:07:18 PM
Also, Getting to the very basis of this thread.. The original poster poses a great question(s)..
On Early to Late '65 Mustangs that were not equipped with the 4-way flashers, Where would the Dealers generally install them?  Under the dash??  Or in the glovebox like '66 cars???  Where were the Emergency Flasher switches installed on Factory installed cars???
Great questions!!
Tony K.
Post by: NEFaurora on May 17, 2013, 11:11:46 PM
Hey, I'm having a brainstorm here.. Also, Who carries the white clearish plastic "holder" that holds the flasher itself in the '66 cars that bolts in near the glovebox to hold the flasher..???
Post by: 5F09CNot4Sale on May 17, 2013, 11:46:32 PM
(http://i399.photobucket.com/albums/pp77/brobbins341/011.jpg) (http://s399.photobucket.com/user/brobbins341/media/011.jpg.html)
This is the 65 emergency flasher unit. As you can see you can take the 66 unit, take off the plate and use it. It will not be 100% but would be "more correct" then a 66 unit mounted in a glove box. Just an idea.
Post by: NEFaurora on May 18, 2013, 06:24:09 AM
Please do post the original instructions.  Also, It looks like the tip of the original switch is painted semi-flat black, or is that a Black rubber tip??
Do tell.
Tony K.
Post by: midlife on May 18, 2013, 08:27:58 AM
Nice!  I've never seen the 65 version.  Both of the 66 reproductions will work just fine, but my prices are a bit better!
Post by: C5ZZ on May 18, 2013, 09:39:53 PM
I have the flasher accessory for my 65, I found the hole to use
that was already in the dash in front of the fresh air vent, it has
a flat in the hole that matches up with the flat on the switch.
My dash is from a 9/64 Dearborn build so the flasher accessory
was either available then or they had planned on it early on.
Post by: C5ZZ on May 18, 2013, 09:44:53 PM
Do tell.
Tony K.
Tony, its a plastic tip.
Post by: C5ZZ on May 19, 2013, 09:41:10 AM
Yours may or may not be missing the black metal bracket.
Here are some pictures of a NOS unit I dug out tonight:
(http://home.comcast.net/~kkeller1/fl5.jpg)
(http://home.comcast.net/~kkeller1/fl6.jpg)
Mine doesn't have the black metal bracket and there is not a need for it,
the hole in the dash has a flat side which lines up with the flat on the
switch so it fits in perfectly. Also the wiring on mine is a little different
from yours, I don't have the blue extension wire and it hasn't been cut
off, I have two of these flashers and they are both the same.
Maybe mine are from a factory install where yours is a over the counter accessory.
Post by: C5ZZ on May 19, 2013, 11:04:41 AM
Just looked at the 65 wiring diagram and it shows the orange extension wire
with the blue wire going to the cigarette lighter, looks like I need to find one
of those or make something up.
Post by: rodster on May 19, 2013, 12:12:03 PM
I have to check the wiring on my flasher sometime.
I have these switches under the dash and am guessing at least the fog light switch was dealer/owner installed since the car is not a GT.
Post by: jwc66k on May 19, 2013, 12:35:13 PM
I think that what you have is the service flasher, not the factory version. How about listing the part number on the harness tag?
Post by: C5ZZ on May 19, 2013, 01:12:56 PM
If you could check where yours plugs in and let us know that would be great!
One wiring diagram I looked at showed the orange wire going to the fuse box,
the other diagram wiring diagram showed the extension and pluging into the
wire for the cigarette lighter.
Post by: C5ZZ on May 19, 2013, 01:21:48 PM
Jim, the harness tag is long gone, when you compare them mine is just
like yours except that you have the bracket and the wire extension.
Look at "rodster"s picture, his is mounting to the dash just like mine
without the bracket.
Post by: C5ZZ on May 19, 2013, 01:36:47 PM
Found emergency flashers listed as a option in the 65 sales brochure.
Post by: C5ZZ on May 20, 2013, 10:02:36 PM
Good point, yes it is a service flasher. Service part # on harness is C5MB-10C840-A, Box is C5MY-15B584-A.
C5MY would be a Mercury part number, maybe it was used on the Comet also which was similar to the Falcon.
Post by: midlife on May 21, 2013, 07:43:24 AM
I use AGX-20 fuses in that spot.
Post by: C5ZZ on May 21, 2013, 08:52:28 AM
Fuse replacement on instructions specify a 20AMP B-14526 fuse. From what I reference that would be a 5 pack of B-14527.
Picture from Ebay:
(http://i.ebayimg.com/t/Ford-Fuse-Tin-1946-1947-1948-1949-1950-1951-1952-1953-1954-1955-1956-1957-1958-/00/s/NDgwWDY0MA==/z/4jAAAOxy14VRQfGp/$T2eC16d,!yUE9s6NFmOPBRQfGos98Q~~60_3.JPG)
As you can see on the side S.F.E. 20 AMP.
Bussman specs:
SFE-14 length: 1-1/6", 27mm
SFE-20 length: 1-1/4", 31.7mm
Problem is the SFE-20 will not fit the bottom horizontal 14A slot on a 1965 Mustang fuse box.
I've read discussion on this issue, but have not seen any answers on what Ford used for a 20 amp fuse in a 1965 fuse box.
Any information out there?
As Midlife mentioned AGX-20 would be the way to go.
Here is the chart for fuses from the Ford MPC.
Post by: C5ZZ on May 21, 2013, 08:57:36 AM
Fuse instructions:
(http://home.comcast.net/~kkeller1/fl9.jpg)
Thanks for the info.
Do the instructions still show for Mustangs application that
the orange extension wire with the blue jumper wire is used
or is the extension not used on a Mustang? If so where do
they show it plugging into?
Post by: rodster on May 21, 2013, 01:52:34 PM
The flasher itself looks longer than most I've seen, is it a unique piece?
Post by: C5ZZ on May 21, 2013, 02:32:01 PM
Yes, emergency flashers are different from regular flashers,
four lights flashing versus two, if you look on it there is a
different number, 536 for four way flasher, 552 for turn signal flasher
Did you happen to get a chance to see where your harness plugs in for power?
Post by: C5ZZ on May 21, 2013, 06:44:57 PM
Fuse instructions:
Maybe you can check your flasher but noticed on mine
it had stamped on it to use a 14A fuse, maybe the fuse
doesn't need to be upgraded?
Post by: midlife on May 21, 2013, 11:02:17 PM
Extension wires (female plugs) are not used in Mustangs.  I believe they were put there for temporary lights (like a movable light to place on the top like a cop car?).
Post by: midlife on May 22, 2013, 08:07:10 AM
That's correct: one wire accepts the cigarette lighter female bullet and passes it on to the lighter itself.
My earlier post refers to the 66 harness that has two female extension leads on the driver's side that don't appear to be used for anything.
Post by: rodster on May 22, 2013, 10:05:58 AM
I took a quick look and think it looks like the the wiring in the drawing picture above but need to double check. It's been too hot lately  to crawl under the dash.  :o
I'm a bit confused.
Is the above wiring drawing the dealer add on method and the factory is different or is that still being resolved?
Post by: jwc66k on May 22, 2013, 06:07:49 PM
This is not true, there is a factory installed extension cable (C5DB-18A919-A) used to supply power to the radio. The extension from the cigar lighter terminal for power to the dealer installed flasher harness is another. There are two triple female socket connectors under the dash (switched and constant voltage) to attach the Rally Pack lights, back-up lights,  radio dial light and other accessories.
Post by: midlife on May 22, 2013, 10:31:08 PM
I think we are talking about two different but related things.  The radio power cable is typically plugged into the three-prong plug tied directly to the fuse box, and that 3-prong plug also supplies power to the backup lamp circuits.  Since most 65's did not come with e-flashers, the radio still had to get power.
For 1966, the e-flasher harness also has two far left extensions: one blue and one orange.  One offers a blinking voltage; the other is always hot (but fused).  These are the female plugs I was referring to that seem to have no usage in Mustangs.  Obviously, they can be adapted.  I suspect the always hot line can be used for the rally pack clock power, but the manuals state to get it off of the door switch.
The two triple female sockets are (1) switched ACC power for radio, back-up lamps, etc., and (2) dash lamp signals for radio, rally packs, etc.
Post by: MWM on May 22, 2013, 11:16:17 PM
Midlife,
I read the following post about the extra wires.
http://thecareandfeedingofponies.blogspot.com/2009/01/emergency-flashers.html
The part of Mark's response was interesting.
Post by: jwc66k on May 23, 2013, 12:42:30 AM
Midlife,
If you look at the 2nd picture in the above link, you will see two wires going to the flasher connections, and they are the same color as the two wires in question in the 3rd picture. The way the circuit is shown in the 65 Electrical Assembly Manual, page 84, they are used for an indicator light. Also in the above link, the harness assembly is identified as NOS, which could be used in several applications (different years, or different models), ones where both the left and right turn signals are the emergency light indicators, the 66 factory original and the NOS replacement, or in an earlier application, (like 64-65) where there is a single indicator lamp in the dash for both left and right turns and that single bulb is not part of the emergency circuit. In order to see activation of the flasher you need an indicator, which is what these two wires do.
You made a general statement and I found it to be potentially confusing, which is why I answered the way I did.
Post by: NEFaurora on May 26, 2013, 11:36:48 AM
" (like 64-65) where there is a single indicator lamp in the dash for both left and right turns"
HUH?!?
You lost me here with this statement..
Please explain.
Tony K.
Post by: C5ZZ on May 26, 2013, 02:13:47 PM
HUH?!?
Please explain.
Tony K.
Tony, on the 65 "Falcon" style cluster there is one indicator light (on the right)
that flashes for right or left turn signals, the indicator on the left is
for high beam, see picture below.
Post by: jwc66k on May 26, 2013, 02:19:01 PM
You beat me to it, thanks.
Post by: NEFaurora on May 26, 2013, 07:45:49 PM
Oh Ok..  I know what you're talking about now...
Has anyone ever wondered why they never did the left side turn signal on the '64-'65 Falcon or '65 Mustang cluster??  It seems weird..
Just curious..
Tony K.
Post by: NEFaurora on May 26, 2013, 07:52:45 PM
It would have made more sense for the High Beam indicator to double as the Left Hand Turn signal indicator.  It doesn't seem like it would have been Rocket science even back then in the '60's to do this.. It would be a nice mod for the '65.  I wonder if anyone has ever considered doing this.  It sure is in the proper place!
Tony K.
Post by: csxeng on January 07, 2015, 08:43:30 PM
Hope this reply helps other members on this question. Six Pictures. The photos uploaded are for the 1965 mustang original Emergency Flasher & Switch which mounts on left side of lower dash in the ā€œDā€ hole. The orange with yellow stripe wire which is spliced to a faded blue with white stripe wire is used to connect to the cigar lighter hot wire, which is the Blue with White stripe wire main harness. The flasher unit is number 536 and is used for this application while the turn signal flasher is number 552. This setup is in my 1965 fastback with a scheduled build date of October 13th 1964. There is only one "D" hole stamped into my lower leftside dash instead of two because of the early production date. Later production cars had the two "D" holes at that location. The Emergency Flasher was an option for the 1965 year. In 1966 the feds stepped in mandating it as standard equipment so the location was in the glove box. Hope these pics help out and feel free to ask questions.
Dave V.
Post by: rodster on January 07, 2015, 10:37:49 PM
Very nice first post.  ;)
Welcome!
Post by: NEFaurora on January 08, 2015, 05:06:36 AM
I have noticed that the 1966 Emergency Flasher wiring assembly has two extra wires with barrel connectors (A Blue wire, and an Orange wire)
Since the 1965 Emergency Flasher wiring assembly does not have these EXTRA TWO BLUE AND ORANGE WIRES, I am thinking that these are redundant accessory wires for extra 1966 accessories.
Does anyone know what the EXTRA TWO BLUE AND ORANGE WIRES with Female barrel connectors are for on the Early 1966 Emergency Flasher wiring assembly ???  Does anyone know?
So according to MIDLIFE, The two extra Female Orange and Blue wires are not used in the Mustang???  Well, What could I use them for if I wanted to?? Extra Power??
My Mid May 1966 Convertible has the Emergency Flasher wiring assembly integral within the harness so it is no help here.
:o)
Tony K.
Midlife....Where are you?
Post by: midlife on January 08, 2015, 08:35:22 AM
I don't see why you couldn't use those female bullet connectors for other purposes.  One is tied into the cigarette lighter; the other could be used for another flasher output.
Post by: NEFaurora on January 08, 2015, 01:26:07 PM
Thanks Midlife!
The point is, On the Mustang, The extra female wires were meant NOT to be used unless you had an added lighting accessory. The '65 harness does not have these two extra blue and orange female wires..and the mid '66 to late 66 harness had the emergency flasher INTEGRAL within the entire harness.
Mystery solved.
I guess if there is any question left, It's what you could actually attach to the extra blue and orange wires that are sitting there not being used. Any ideas??
I'm thinking that I could use the extra Orange wire for an added cigarette lighter power source for my IPOD.  That would be a good use, but I would probably have to ground the outside of it to make it work.
Tony K.
