Restoring - General discussions that span across many different groups of years and models => Misc Items => Topic started by: koski19 on May 22, 2013, 12:32:57 PM
Is there any way to test an Internal Voltage Regulator?
I used my auto ranging volt meter and on the Ohm setting it showed OL on the meter
which tells me the IVR needed to be replaced.
Jeff
Probably information in the Ford shop manual that would help with this. If you don't have a copy, would highly recommend you purchase one.
Depending on what year you have (it's a good idea to include that in any post), you have at least two gages that use the 5 volts the low voltage regulator puts out. There are two main causes for it to fail, the contacts are fused, or the heating coil opened (burnt out). A bench top resistance reading across the two terminals will read zero ohms, which is the normal unpowered state. Take a reading from the female spade connection to the regulator case and you should get a low resistance reading which indicate that the coil is OK. The in-car test requires access to the regulator usually mounted on the back oft he instrument cluster, and with the ignition switch to accessories, you should get a reading of about 5 volts (it may go up to 10) on the input connection lead (black-green stripe) to the fuel gage. Most of the time, if the regulator was thought to be defective, it was replaced.
If you're asking about the IVR used behind the instrument cluster I posted test procedures on the VMF a few years ago:
http://forums.vintage-mustang.com/vintage-mustang-forum/493976-instrument-panel-voltage-reg.html#post3082029
http://forums.vintage-mustang.com/vintage-mustang-forum/493976-instrument-panel-voltage-reg.html#post3082029 (http://forums.vintage-mustang.com/vintage-mustang-forum/493976-instrument-panel-voltage-reg.html#post3082029)
Yup, the old analog voltage meters are a must, as the digital volt-ohm meters react too quickly for the slow IVR voltage changes.
Another issue that can cause you to think the IVR is bad are crappy connectors to the IVR: the molded connectors themselves...ask me how I know!
Ooops.....It's a 66 with gauges......Thanks for the info......This will need to wait until the car is back together.........Jeff
Thanks for the link...It's now in Favorites.........jeff
