1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year => 1967 Mustang => Topic started by: Angela on June 09, 2013, 08:57:32 PM
Title: Tail light to body hardware
Post by: Angela on June 09, 2013, 08:57:32 PM
I've noticed that every hardware kit one can buy (including AMK) to attach the taillight buckets to the tail light panel (body) include 10-24 "keps" nuts with integrated washer "teeth".  For the longest time I figured that must be the correct style of nut used in this application. However, when installing the plastic wire protectors onto the 10-24 studs (after the keps nut) I noticed it seems like the stud is way too long or the wire protector cap is way too shallow. Looking back at my box of original taillight hardware, I noticed that the 10-24 nuts were not keps, but stamped machine-thread type with a form of mastic inside the nut. These stamped machine thread nuts are at least twice the depth of the keps nuts supplied with the AMK kit. When the stamped nuts are installed the wire protector plastic cap fits perfectly.
So, my question is whether thin keps nuts or the "taller" stamped machine thread nuts are correct.
This might be difficult to imagine without a picture. I'll try to grab a photo...
Title: Re: Tail light to body hardware
Post by: J_Speegle on June 10, 2013, 12:15:43 AM
Believe your doing a 67 San Jose car
If I understand you question its typical for the stud covers not to hide all the threads on the mounting shaft
Here are a few pictures that might (?) help - let me know if the answer is no and I try and find something
(http://i44.photobucket.com/albums/f49/firetrainer/67%20Mustang/67%20San%20Jose/7R03C188372PStl_zps12362285.jpg) (http://s44.photobucket.com/user/firetrainer/media/67%20Mustang/67%20San%20Jose/7R03C188372PStl_zps12362285.jpg.html)
(http://i44.photobucket.com/albums/f49/firetrainer/67%20Mustang/67%20San%20Jose/7R021C169880tl_zpscf2f30f5.jpg) (http://s44.photobucket.com/user/firetrainer/media/67%20Mustang/67%20San%20Jose/7R021C169880tl_zpscf2f30f5.jpg.html)
(http://i44.photobucket.com/albums/f49/firetrainer/67%20Mustang/67%20San%20Jose/7R021C169880PStl_zps14e9aff2.jpg) (http://s44.photobucket.com/user/firetrainer/media/67%20Mustang/67%20San%20Jose/7R021C169880PStl_zps14e9aff2.jpg.html)
Post by: 67gta289 on October 06, 2016, 07:46:09 AM
Dragging this topic up.  I did search elsewhere and did not find the answer to this related question - how many of the 12 tail light screws (6 per side) had the gray plastic screw protector?
I have a picture of an unrestored 7F02C200xxx that shows the driver's side had them on all three top screws, and the inner most bottom screw.  The other two bottom screws did not have them.  I don't have a picture of the passenger side.
Post by: 67gtasanjose on October 06, 2016, 08:24:00 AM
This seems to be the trend of what Ford intended for both sides (siting memory) I added them to all 6 of mine at one point (just because, I suppose) and they often get knocked off loading & unloading cargo so I MIGHT have 4 remaining now.
Post by: ruppstang on October 06, 2016, 09:30:17 AM
The four as shown in your picture is what I have found as correct. Others may have a different opinion.
Post by: jwc66k on October 06, 2016, 04:48:45 PM
When in doubt, use the book: 5 are indicated in the B/M (both 67 and 68, 353358-S), 2 on the RH upper inner studs, 2 on the LH upper inner studs, 1 on the LH lower inner stud. After a couple of decades of vehicle use, who knows how many were installed, how many fell off and were incorrectly replaced, how many fell off and were tossed, etc.
Post by: J_Speegle on October 07, 2016, 07:02:48 PM
Not meaning to be argumentative - just stating another opinion :)
Sure any long term member here sees examples, in out responses, how comfortable and how much value we each, individually place resource and reference.
Agree allot can change over the years but there are enough mistakes, workers choose not to do it the way the "book" suggested, or they changed the "book" the following day  for me to accept many of the details there. In most of the really nice unrestored examples we find it appears that in the trunk, especially, there was little touched or altered or reason for it as in allot of cases the trunk and back seat were rarely if ever used.
If we see one (for example) not there that the "book" suggest should have been installed I think we have a responsibility to at least discuss the possibility that that plant and those two-three workers didn't install them for some reason
Post by: jwc66k on October 07, 2016, 08:33:26 PM
Absolutely. However, a car is judged to a standard according to MCA. If a car being judge is missing a cap that requires one in the trunk, a competent judge will note that missing cap and deduct a point. The car owner will be upset. An argument will ensue. The car owner will cite pictures and opinions and precedents, but without documentation acceptable to the show sponsor, it is a losing argument. To be safe, knowing what I stated above happens, following the book is not a bad idea. Of course, it's only one point.
Post by: Bob Gaines on October 08, 2016, 12:12:50 AM
I know what idea you are trying to get across but for others reading technically if any, only a percentage of a point (percentage of point value for that area) might be warranted.  MCA does not count partial points. The minor deduction may be added up along with other minor deductions from that same category and possibly be given the weight of "a" point when taken into consideration along with the other less then one point deductions. There is typically a "catch all" area for items mentioned but not deducted for in the category being scored. That way, less then 1 point valued items are not ignored or given more weight then they deserve. Also if the combined minor deductions still don't have the combined weight of one point then the deduction is dismissed although the information is still on the sheets for owners to consider. I only mention it so others don't get the wrong idea that every incorrect item is at least 1 point deduction.
Post by: mtinkham on October 19, 2016, 01:44:24 PM
I did a few searches for leaking tail lights (taillights, taillights) and did not find anything.  I am putting together a 67 coupe (final stages of a restoration....yeah) and wanted to try to prevent leaks into the taillight assemblies.
Any suggestions for preventive measures would be appreciated.
Mark
Post by: jwc66k on October 19, 2016, 02:03:46 PM
Mark,
Do you have leak a problem now, say from body damage? If not, I would use the replacements available.
Post by: mtinkham on October 19, 2016, 06:52:11 PM
Jim,
Taillight assemblies were leaking prior to the restoration.  Going back together now, with all original Ford components.  I didn't know if I should double-up on the lens-to-bucket seal, which would push the thick body seal further out of the bucket assembly.  Wasn't sure if I should add some sealer between the thick body seal and the body?
Just looking for any proactive steps I can take to prevent leaking.
Thanks.
Mark
Post by: J_Speegle on October 19, 2016, 10:32:22 PM
Jim,
Might want to consider some non-factory methods to insure a positive seal in a hidden area of your car.
Post by: mtinkham on October 21, 2016, 01:40:15 PM
Thanks Jeff.  That is what I was seeking from the experts on this forum...any suggestions or proven methods? Again, I did a search for sealing / leaking tail lights and nothing came up.
Thanks in advance.
Post by: 67gta289 on October 21, 2016, 02:37:34 PM
Just a thought (have done in other cases but not this) is to use a clear dielectric compound to fill in any gaps.  It does not harden, can be removed, and is water proof.  In this application where there is the potential for water seepage but no direct stream with pressure, it probably would work great.
Post by: jwc66k on October 21, 2016, 04:39:16 PM
I like this, it might just work.
Double sealer gaskets work, sometimes, I've done that on a Dodge. Give that method a try. I've noticed that some aftermarket gaskets are an open cell type while originals were a closed cell. What were the originals, and what are the replacement materials?
Another thing to try is Scotch Guard fabric sealer. I spray it on the 64-66 defrosted ducts and plenum as a moisture repellant. It is a clear spray. It might repel water on the sealer gaskets.
Another consideration is strip calk. I can think of a few other sealing methods, but my own personal methods require doing nothing that would be difficult to reverse or clean, like weather strip adhesive (like 3M 8008 or 3M 8001).
Post by: 67gtasanjose on October 21, 2016, 05:10:45 PM
Thanks in advance.
Chances are great that the leak comes in around the studs at the bezel (outside). a bit of strip caulk wrapped around the stud up against the bezel won't hurt ;)
Post by: mtinkham on October 24, 2016, 02:01:33 PM
Thank you for the information....as usual, very informative!!!
