1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year => 1970 Mustang => Topic started by: saacman on July 12, 2013, 09:06:21 AM
would like some info. if possible looking for correct info. for the paper sticky decal that went on the front engine block . i notice in the aftermarket they have quite few different ones. Info on car is as follows: 9/69 Dearbon built (Sept.29 '69 actually date of build) , 428 CJ Ram- Air , Mach 1, 4- speed toploader. hope this is all that is needed to get correct decal all help is grt8ly appreciated .
Do you have the original aluminum engine ID tag? The engine identification number will be on there. Here is some info that might help: http://www.fordification.com/tech/engineIDtags.htm (http://www.fordification.com/tech/engineIDtags.htm)
If you don't have the aluminum tag, hopefully someone will be able to narrow it down to a single correct answer.
Paper tag/sticker will go on the front of the passenger side head - no the block
For your 428 CJ 4 speed buildsheets (source of the info) show 420S
thank you for all info. no unfortunately i dont have the engine aluminium tag or the rear end tag, im working with Kevin Marti to acquiring those
