1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year => 1968 Shelby => Topic started by: dwdshelby on December 04, 2013, 01:31:57 AM
Title: 1968 GT 500 KR Rear Brake Lines
Post by: dwdshelby on December 04, 2013, 01:31:57 AM
Hi, I have searched the website for this but didn't find any info ... but I recall reading somewhere that the rear brake cylinders on the 1968 KR were the same units on both sides (C7ZZ 2262 which is the left one in the general mustang parts books). Is this true? I have two of these but then the next question is where to source a good set of rear brake lines that would fit and that are cosmetically correct? My originals are pretty dirty and stained especially the wire wrap guards. Baring sourcing some new or NOS lines, is there a way to restore the originals to reuse? Otherwise, they are not bent or damaged.
Thanks for all your help.
Dwdshelby
Title: Re: 1968 GT 500 KR Rear Brake Lines
Post by: TLea on December 07, 2013, 08:07:00 PM
all 68 shelbys use the C7ZZ A cylinders on both sides.
no real way to restore brake lines but reproductions are decent. confusion comes the way catalogs list the lines because most use 28 spline line sets even though all have 31 spline axles. is your car a 4 spd or auto?
Post by: J_Speegle on December 07, 2013, 08:20:55 PM
Thanks Tim :)
Post by: dwdshelby on December 08, 2013, 06:56:18 PM
Hi, thanks Tim.
It is an auto car.
Best
Dwdshelby
Post by: TLea on December 11, 2013, 10:49:18 PM
Automatics use the 28 spline brake line set with the C7ZZ 28 spline brake hose
Post by: ruppstang on December 12, 2013, 09:11:02 AM
Would that be true on a automatic 68 GT 350 as well?
Post by: TLea on December 13, 2013, 06:41:12 PM
Yes. All 68 Shelbys are the same 28 spline line/hose set (even though they are 31 spline) except KR 4spd which uses the 31 spline set
Post by: ruppstang on December 15, 2013, 10:33:32 AM
Boy that is confusing looks like I will be making a return. Thanks Tim
Post by: specialed on December 15, 2013, 01:08:17 PM
Not really confusing the 68 1/2s & KRs with 4-speed have rear staggered shocks & vent hose is moved to outside more & brake hose moved inside more having 2 separate holes for exhaust pipe clearance around staggered shock mount & special brake hose & brake line bends routing different.
Post by: Bob Gaines on December 15, 2013, 05:00:14 PM
The author has a Automatic not a four speed  .
Post by: ruppstang on December 15, 2013, 10:03:36 PM
Ok I guess I am a little slow. What is confusing to me is if all 68 Shelby's are 31 splines why do they use the 28 spline line and hose sets?
Post by: 69bossnut on December 16, 2013, 12:01:44 PM
dwdshelby,
I am reproducing the correct single crimp brake hoses. I have both the C7 rear & the C8 rear hose. For your car being a 4 speed it will use the C8 hose. For the fronts I only have the hoses for disc brake cars at the moment. I also have the correct 1/4" small bleeder wheel cylinder for your car. All my contact info is in my signiture below. You can check out the hoses on my website listed below as well.
Let me know if I can help.
David
Post by: TLea on December 17, 2013, 08:47:43 AM
Its really not confusing, its the way the vendors advertise. 28 or 31 spline has nothing to do with the brake lines but thats the way they advertise them. It should be sold as,
1. 68 Mustang/Shelby 9" rear axle brake lines, all except 428 CJ/KR 4 spd
2. 68 Mustang/Shelby 9" rear axle brake lines 428 CJ/KR 4 spd
Like Ed said its the relocated axle vent of the staggered shock not the spline
Post by: TLea on December 17, 2013, 08:52:05 AM
dwdshelby,
David
David, his is an auto which uses the C7
To anyone who doesnt know David, he makes some much needed very high quality reproduction parts and is a pleasure to deal with. In addition to the hoses and wheel cylinders he also makes beautiful strut rod bushings, rear axle line straps and many Boss 302/Boss 9 parts.
Post by: specialed on December 17, 2013, 10:19:21 AM
+1 on davids parts & he was at shop recently getting brake hoses for early cars he is working on making CONCOURS correct also.  I forgot (in my post) the rear brake line to brake hose strap holder being different (longer) on 68 1/2''  4-speed cars right TIM?
Post by: TLea on December 17, 2013, 01:16:04 PM
correct
Post by: 69bossnut on December 17, 2013, 04:26:17 PM
Guys,
Thanks for the feedback. I guess for some reason I thought his car was a 4 speed car. I do have both styles of the axle hose strap as well.
