1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year => 1964 1/2 - 1965 => Topic started by: rockhouse66 on December 29, 2013, 02:03:40 PM
I searched myself silly looking for an answer here but didn't find one, so here goes. I assume (?) that the area under the cowl panel (louvered panel in front of the windshield) was red oxide. Yes?
The assembly manual instructs ESB M7C29-A rust preventative be used "under cowl top panel at louvered area". What color is this rust preventative and how the heck would they do this once the cowl is in place? Through the vent openings maybe?
It also says this should be done "subsequent to final body color application". Well, the definition of "subsequent to" means after, so how did they apply anything to the back of the louvers after body color was applied and not get it all over the finish paint?
I must be missing something fundamental here.
OK, I was thinking about this upside down (literally). I have it figured out now EXCEPT I am still interested to know the color and particulars of the rust preventative ESB M7C29-A.
The rust preventative is probably a zinc coating, although, like you, I have no idea how any coating could be applied once the cowl is welded in place.
Charles
My paint guy figures they used something called a needle gun and stuck it down in the cowl louvers. It must have been some sort of black paint, to black out the plenum and erase the body color overspray that would otherwise look ugly down in there. Seems someone in the hobby would know how to translate these codes though - since they are used throughout the assembly manuals.
I tried Google and found places you can go to read the specifications, but none of the descriptions I found actually provide any info. One site will sell you a PDF of the actual spec sheet for $30. I guess I don't want to know that badly ::)
I'm not recalling any 65-66 cars that I observed with original paint and blacked out inside the cowls. Do you have any examples?
Well, I guess I "assumed" they were blacked out in there since the assembly manual suggests something was done, and it would definitely improve the looks. No, I don't have any original examples. I'm just trying to figure out what the assembly manual says to do here.
So, an original paint car - assume it is white - would have basically zebra stripes beneath the cowl grill? Would they be red oxide/white or black/white?
As much trouble as Ford went to, blacking out things like horn wires so you can't see them through the grill, you would think they would do something in this area to improve the visual.
Just me but I would never use the assembly line manuals to guide me on how to apply sealer or paint on a restored car. ALLOT of the details shown are nothing like what they did on the line ;)
No zebra stripes just body color overspray from the paint application fading towards all side to no paint the further away the panel is from the opening (cowl vent on the top of the cowl) I've never seen black as a base and never red oxide visible unless the exterior color has started to chip or bubble from age and rust
Just prep it and then apply the body color from as many angles as possible IMHO the challenge is producing a large amount of oversray as they did originally with the new paint guys most painters have. And don't over think things too much ;)
Based on how many I have seen that are rusted out in all the early fords I always thought, other than what blew through while the car was painted, they used no paint at all inside the cowl.
+1. If you are concerned about rust protection you could prep accordingly and cover with a metal color paint before final coat. Most effective when cowl is a part so you can get to bottom side of fins etc.
I remember reading somewhere, maybe in Ford docs, that the cowl structure pieces were originally left bare steel, but then later on in production, the parts were zinc plated for further protection. I've seen this first-hand when stripping paint off a cowl this zinc plating. Same coating using on the heavy steel uni-body components like frame rails, etc...
