1st Generation 1964 1/2 - 1973 - Questions & general discussions that apply to a specific year => 1964 1/2 - 1965 => Topic started by: drummingrocks on November 13, 2014, 10:41:37 AM
Does anyone have a source for a correct rivet for the weatherstrip that rivets to the top of a '65-66 vent window frame? The rivet that comes with the repros is just a standard rivet, whereas the original rivet had a larger head and fit the frame much better.
Here's the piece I'm referring to: https://www.npdlink.com/store/products/seal_vent_window_to_door_post-103803-0.html
Also, does a '67-68 use a similar setup? I purchased new window runs for my '67 coupe, and it appears that they too are meant to rivet to the top of the window frame.
I'm not aware of anyone making an exact rivet. The originals look like they were chrome finish too.
67-8 uses a screw instead of a rivet, the top seal is made into the vertical run.
Charles, my main gripe with the last set of rivets I used was that they were more of a button head/standard rivet, whereas the original rivet had a flat head that perfectly filled the hole in the vent window frame.
Good to know that a '67 uses a screw instead of a rivet--that will save some headache! Thanks!
This photo doesn't really show the heads of the rivets, but I wonder if the rivets in this Scott Drake kit are more correct?
Here's the link: http://www.cjponyparts.com/scott-drake-vent-window-rivet-tool-kit-1965-1966/p/HW1456/ (http://www.cjponyparts.com/scott-drake-vent-window-rivet-tool-kit-1965-1966/p/HW1456/)
Probably about the best you will find. Only other option is having them custom made at Hanson Rivet, believe it's a 500 minimum.
Charles, is that tool/punch that's included in the kit the same thing I would need to install the glovebox door emblem we talked about in the other thread?
Hard to tell from the pic, it might flatten the rivet instead of spreading it.
My measurements for 64963-S as shown on Illustrated Section 230 page 5, 0.144D,0.250L,0.312D HD,0.035T HD,0.101ID 0.137L RECESS
From Granger, some options, see link for prices:
Steel, zinc plated, 1/4 L, pk 100
http://www.grainger.com/product/Semi-Tubular-Rivet-1HBP8?s_pp=false&picUrl=//static.grainger.com/rp/s/is/image/Grainger/1HBP7_AS01?$smthumb$
Aluminum, 1/4 L, pk 100
http://www.grainger.com/product/Semi-Tubular-Rivet-1HCL7?s_pp=false&picUrl=//static.grainger.com/rp/s/is/image/Grainger/1HBP7_AS01?$smthumb$
Stainless, 5/16 L, pk 50
http://www.grainger.com/product/Semi-Tubular-Rivet-1HEE3?s_pp=false&picUrl=//static.grainger.com/rp/s/is/image/Grainger/1HBP7_AS01?$smthumb$
Steel, zinc plated, 5/16 L, pk 100
http://www.grainger.com/product/Semi-Tubular-Rivet-1HBP9?s_pp=false&picUrl=//static.grainger.com/rp/s/is/image/Grainger/1HBP7_AS01?$smthumb$
I used the rivets in the kit but I needed to fabricate a die to stake and flare the bottom with my rivet tool.
Thanks, Jim. Would the stainless or zinc plated steel be more correct?
The originals look chrome plated, so stainless would be your best bet.
Also, think I mentioned it before, that the originals are tapered from the top to fit the hole in the vent window frame.
You're right, I forgot about that. The lack of taper might be what makes the reproduction fit so badly.
