General Discussion => General Discussion => Topic started by: ppc66 on December 06, 2014, 12:29:51 PM
Just thought I'd share my strategy for purchasing Evapo-Rust... I've been purchasing it through Advanced Auto using their 30% off any order coupon code - TRT30. Around here it's 22.99 - Get's the price down to about 16.09. Place an order through their website, pay via CC and go pick it up.
There's another code - TRT37 that I've been considering using which is $30 off orders over $75 . So, for 4 Gallons of ER-
Price: $22.99
Add'l Discount: -$30.00
Total: $61.96
That's $15.49 each!
Not a bad deal if you need that much. Always check for coupon codes other places online rather than use what the banner on their webpage is offering. Of course this strategy doesn't apply to just buying ER - Just thought I'd share because IMO this hobby doesn't offer as many opportunities for discounts (like for example the stores SWMBO frequents). We certainly pay to play!
Best regards,
Perry
Wow, good tips! Thanks I'll certainly look into this. ;)
Thank You, Perry. I have never used Evapo-Rust, but I'd like to try it. I have been using POR-15 & Eastwood products with great results, but I am always willing to try something that, obviously, has been working well for others. What is the product size, weight, pounds or however it is packaged? Thank You. Jerry
They sell it in 32Oz and 1 gallon jugs in most stores - From what I've read also 5 gallon buckets, 55 gallon barrels and other industrial quantities.
- Perry
Thank You. I'll have to read up on how the proper way to use it is and how much coverage.
- Perry
Is that the one that is in a gray colored jug?
That is the one. The gallon that AA sells is Part No. ER012.
There are a lot of threads on this site (and others) detailing usage and getting the longest life out of it. The way I most recently used it was for cleaning up the backing plates and spring perches on my rear axle. I have the 7-1/4 rear and stood it on end in a 5 gallon bucket that had 2 gallons of evapo rust in it after removing the brake hardware. Since 2 gallons doesn't quite come up high enough to reach the spring perches I used a small HF pond pump and some clear tubing to spray it where needed. The product needs to soak the part continually to work. Can't just spritz it on - it has to soak. I left the axles/seals in the rear, and I don't believe the ER affected the seals. For the rest of the axle housing I used sandpaper and wire brushing since those areas weren't that bad. Over the past year I also messed around with white vinegar, electrolysis, sand blasting, muriatic and phosphoric acid. Those experiments might turn into another post... some of these rust removal topics can be quite polarizing and become unpleasant to read on other sites!
-Perry
-Perry
Most everyone has a method for everything they do that works for them. But, by keeping an open mind, you may find a way to do things that you like even better. Sharing ideas should not bring ridicule.
Yea, feel free to share anything you learned, I know I'm always interested in knowing more.
I did find Evaporust can be effective by 'spritzing' on with a pump sprayer followed by a wire brush if repeated many times on parts that are too big or can not be removed. The downsides are more than likely any factory paint markings would be lost by wire brushing and it's somewhat wasteful since more Evaporust is probably used compared to soaking and it takes more time.
But it can be done. ;)
I added a little detergent to the spray to help create a foam that would stay on the surface longer.
Thanks for posting. I normally only buy 5 gallon quantities. O'Reilly auto parts has it on their website with free shipping, usually around $80-90. If you're just doing fasteners, a gallon will go a while, but nice to be able to soak the bigger stuff. I tried evapo-rust in an ultrasonic cleaner, seemed to be quicker.
I've also wondered about pumping it across things too and mentioned trying it in another thread about E.R.. I have to wonder how quickly it evaporates when pumped and until a need might present itself, submersion seems to be the best option. Wheels might only use about 8 gallons to submerge if a tank or pan is close to the diameter of the wheel, keeping in mind it can be flipped over and/or completely submerged. I like the idea of the rain gutter on driveshafts. If we think about it, chances are we can find something already in our junk collection or at the nearby harware store that closely fits the job task we have. With all that replacement parts cost and add in the magic this product seems to pull off, it looks like most of us could get by on 5-7 gallons and get everything we could use it on done for around $100 of product. How much is YOUR time worth by the hour? Restoration shops get typically +++$75/hour to do the work.
I am willing to try anything once, starting on smaller projects and then moving up towards the larger ones. Translation: I'll buy a couple gallons and use it on a few of the smaller things and then plan to buy a 5-gallon supply as I figure things out.
Keep posting YOUR ideas here or other areas of this site. NEW ideas are not always better but FAILED attempts help others too, so by all means share all experiences with this (or these) type of products!...ALL, The GOOD, The BAD & the UGLY!
The plastic oil drain pan for a diesel that you find at some Walmarts and auto parts store worked perfectly for me to soak 14" styled steel wheels. Holds around 4 gallons. The wheel barely fits through the top and more than half is submerged. Soak, flip wheel over, repeat. The plus is the oil drain pan has a spout to then pour the EV back into gallon jugs. I pour mine through a paint filter to remove anything large.
I use a 4 inch PVC pipe with a cap on one end for driveshaft's. It takes about 1.5 gallons.
Some very good ideas. I was going to ask about saving and re-using E.R., but you answered that for us all. Thank You. Do you put the 'used' product (after straining) back in the container with the new? Or different container?
Some very good ideas. I was going to as about saving and re-using E.R., but you answered that for us all. Thank You. Do you put the 'used' product (after straining) back in the container with the new? Or different container?
p
I've been doing this exact thing tonight. I used my little fountain pump wrapped in a rag to strain and pumo out what was in my soak bucket into 3 of the original containers. In a fourth I placed a funnel jammed with a coffee filter under a scotch brite pad into the funnel outlet and filled the funnel with ER from one of the other 3 containers. It's trickling into the fourth container now and I'll take pics of the the result of flitering compared to not filtering through the filter. Its pretty dark looking because despite my best efforts to degrease some parts (e-brake cable) idk if I did well enough.
The ER in the measuring cup is filtered, it is a little lighter than the one in the jar. The brake cable came out pretty well compared to what it started as.
......... Place an order through their website, pay via CC and go pick it up.
Just checked, none of my local stores show it in stock or only have a gallon. Did your store have 4 gallons in stock?
Typically the individual stores don't keep it in stock but instead have it sent over from the distribution center.
So I'm guessing I have to call my local store and ask them to get 4 gallons in so I can buy them on line? That should confuse them. ;)
Like with other online sales the transaction and pick up/delivery location logistics are handled automatically .You don't have to contact the store. The only time you have to talk directly to your local store is when you want to buy from them in person and not online. I would suggest to call ahead to give them some time to get the larger quantity there. Last time I did it I called in the morning and they had it over from the warehouse for pick up that afternoon. Another time I called a little later in the day and had to wait until the next morning.
Since I'm usually impatient... I have several stores nearby and they're all on my route between my house and office. Last time I bought some each store only had 1 Gal each and I wanted 2 gallons. On the website order page I ordered 1 from each store I would pass by. Do this by selecting qty 1 and select the location, go back a screen, add another line item for the same item and select another location to pick it up from.
I am a software developer and the company I work for makes an ERP/Accounting/Inventory control software package... so I know never to trust anything when it says QTY 1. My point being you should call to make sure they can physically put their paws on the one. It would be annoying to place an order and find they actually had qty 0 when you got there.
There are a TON of helpful evapo rust pages on this site! Never imagined this could become one of em! :)
-Perry
You do if your want to buy 4 from the same store. ;) See attachment
-Perry
I've actually called ahead to verify an item was in stock and apparently they are looking at the same database as me (not checking actual stock). When I arrive, qty =0 on the shelf even tho' the system says not. Yes, quite annoying. ;)
If I decide to buy 4 gallons of ER from AA I'll call and ask if they can actually see 4 gallons -before- I arrive. ;D
The stores around me never have more then one gallons amounts on hand like I said before .That is typical of most advanced auto's ,Orielly's etc. If I order a quantity online it gets automatically shipped to the store in question. The online thing will take a day. If I am in a hurry and it is still early in the day I can call my local store directly and they will have the 5 gallons brought over on one of the many parts runs they typically do between the warehouse and the different satellite stores each day .I would do that before driving all over the city collecting gallons . I always call ahead regardless of which way I do it so I don't waste a trip if it hasn't arrived yet. The point I was trying to make that you clearly didn't get is that when you do a online order that is how you order only . If you do a phone order you order by phone only and not also online . You don't do both unless you want confusion. Your reply #17 has to be a attempt at sarcasm because you couldn't be that mentally challenged.
Don't doubt me for a moment! ;) but hey, where's the smiley after your comment? :)
This has gotten way too complicated....but what I was attempting to convey is you CAN NOT order a quantity (4) online if the Advance Auto store does not have it it stock, the menu comes up to Call Store hence you can not do an online order w/o calling.
My other attempt at sarcasm (I need to work on that) ;) is that I've dealt with parts store counter folks that have no clue what they are doing and only believe what their sales terminal tells them.
So Bob, thanks for your concern for my mental health and the instructions to purchase items from a parts store, that will come in handy next time I need to buy something. Friendly sarcasm. ;D
Happy Holidays to all!
By the way, I'm sure to the outside world not involved in concours details such the correct finish on a nut, we must all seem mentally challenged! ;D
