Author Topic: Metal plate(Z shaped plate) under fuse box on 67/68  (Read 1210 times)
Offline 1965GTFB
« on: September 18, 2013, 07:17:46 PM »
Need the metal plate that mounts under the fuse box on 67/68.  It may only be on cars that had fog lights or AC.  It has a spot for a relay to mount on it to the left side.
If you have one email me
nelsons565@yahoo.com
Re: Metal plate(Z shaped plate) under fuse box on 67/68
« Reply #1 on: September 18, 2013, 07:58:37 PM »
Called a "Relay Mounting Bracket". Ford part number 14A301 (1967) & 14A323 (1968 Gold and "Z" shaped).
They may be different between the years. If you have the specific (1967/1968) Electrical Assembly Manual for Mustang they should list the part number.
« Reply #2 on: September 18, 2013, 10:02:18 PM »
I have one but as I said a 67 should use a different wiring arrangement. Was your parts car a 68?
Marty
« Reply #3 on: September 18, 2013, 10:20:13 PM »
I got a nice 1968 one already mounted on the fusebox and it has the relay attached to it.  PM me or e-mail me at harnesses at fusemail.com
Randy
