Author Topic: Hardware sizes and their location master list?  (Read 2242 times)
Offline hkopp
« on: January 25, 2019, 02:32:52 PM »
Does anyone know if a list of bolt sizes and their locations exist for pre 1973 mustangs? For example, AMK has a good catalog of hardware and a part number for a specific use, however I'm needing to know what that bolt (or screw) size actually is.
AMK has a lot of the hardware, and a few even state the thread size but not the length. But some hardware isnt listed, for example the lower dash bolts in a 69/70 mustang. Once the thread size is determined, do I use the 1" long bolts I have, or the 1 1/4"?
Just curious if there is anything documented anywhere, a website, restoration book, etc. After 50+ years of previous owners taking things apart, you'd think this would be a resource someone has needed before.
https://www.amkproducts.com/Catalog_PDF/220-295.pdf
1956 Ford F100
1959 Galaxie
1960 Chevy k10 sb
1965 Mustang 347, 5 spd, 1st car!
1967 Camaro SS350 all #'s
1967 S code
1969 Mach 1 428SCJ-R #'s
1969 Mach 1 428CJ-Q Auto
1969 Mustang Grande, 650hp, 2nd car!
1970 Mustang
1970 Mach 1 351C
1975 Ford F250, 44s, 21" lift, 3rd car!
2002 Avalanche
2011 Vette
Offline hkopp
Re: Hardware sizes and their location master list?
« Reply #1 on: January 25, 2019, 02:40:08 PM »
I just happened to scroll into the library for the 1st time (I know...I know), and ran across this.  Seems like that always happens after I post.  :(
http://www.concoursmustang.com/forum/index.php?topic=11425.0
1956 Ford F100
1959 Galaxie
1960 Chevy k10 sb
1967 S code
1970 Mustang
1970 Mach 1 351C
2002 Avalanche
2011 Vette
« Reply #2 on: January 25, 2019, 03:50:44 PM »
now you know.
« Reply #3 on: January 26, 2019, 12:06:44 AM »
Also you can find the bolt in the assemblyline manual if you like more visual aids. The fastener in the manual will have a number by it . You cross reference the number in the manual with the list of numbers in the back of the AMK guide to fasteners which is a modern companion book to the assemblyline manuals . When you find the number in the AMK list it will indicate a page in the book . When you go to that page you will see a picture of the bolt in question and then if you match the assembly manual number on the page you will find the length ,thread etc.
